Advanced Joint
Advanced Joint
Class AdvJoint()
AdvJoint(parent='MODEL', name='AdvJoint_n', label='AdvJoint_n', active=True, type='PointToCurveJoint',
b1=None, b2=None, origin=None, origin2=None, crv=None, crv1=None, crv2=None, surf=None, surf1=None, surf2=None,
defcrv=None, defsurf=None, rm='Global_Frame', rm1='Global_Frame', rm2='Global_Frame', ic_use_icm=False,
ic_use_icm1=True, ic_use_icm2=True, ic_use_xyz=False, ic_use_vel=False, ic_x_disp=0, ic_y_disp=0, ic_z_disp=0,
ic_use_xyz1=False, ic_vel=0, ic_use_vel1=False, ic_x_disp1=0, ic_y_disp1=0, ic_z_disp1=0, ic_vel1=0,
ic_use_xyz2=False, ic_use_vel2=False, ic_x_disp2=0, ic_y_disp2=0, ic_z_disp2=0, ic_vel2=0)
Create a PointToCurveJoint, CurveToCurveJoint, PointToSurfaceJoint, CurveToSurfaceJoint, SurfaceToSurfaceJoint, PointToDeformableCurveJoint, PointToDeformableSurfaceJoint.
Keyword Arguments
Argument | Data Type | Description | Default |
name | String | The variable name. | AdvJoint_n, for next available integer n. |
label | String | The descriptive label. | AdvJoint_n, for next available integer n. |
parent | Object | The parent. | MODEL |
active | Boolean | Used to activate or deactivate this entity. | True |
type | Enum | The type. One of: PointToCurveJoint, CurveToCurveJoint, PointToSurfaceJoint, CurveToSurfaceJoint, SurfaceToSurfaceJoint, PointToDeformableCurveJoint, PointToDeformableSurfaceJoint. | PointToCurveJoint |
b1 | Body | The first constrained body. | None |
b2 | Body | The second constrained body. | None |
origin | Point | The point on body one which is constrained to body two. | None |
origin2 | Point | The point. | None |
crv | Curve | The constrained curve when type is PointToCurveJoint. | None |
crv1 | Curve | The first constrained curve when type is CurveToCurveJoint. | None |
crv2 | Curve | The second constrained curve when type is CurveToCurveJoint. | None |
surf | Surface | The constrained surface when type is PointToSurfaceJoint. | None |
surf1 | Surface | The first constrained surface when type is SurfaceToSurfaceJoint. | None |
surf2 | Surface | The second constrained surface when type is SurfaceToSurfaceJoint. | None |
defcrv | DeformableCurve | The constrained deformable curve when type is PointToDeformableCurveJoint. | None |
defsurf | DeformableSurface | The constrained deformable surface when type is PointToDeformableSurfaceJoint. Defaults to None. * rm (Marker) - The reference marker for the curve and surface for type PointToCurveJoint or PointToSurfaceJoint respectively. | Global_Frame |
rm1 | Marker | The reference marker for first entity for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | Global_Frame |
rm2 | Marker | The reference marker for second entity for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | Global_Frame |
ic_use_icm | Bool | Use initial condition marker for curve and surface for type PointToCurveJoint or PointToSurfaceJoint respectively when True. If False, initial condition information is defined with respect to the reference marker. | False |
ic_use_icm1 | Bool | Use initial condition marker for first entity for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. when True. If False, initial condition information is defined with respect to the reference marker. | True |
ic_use_icm2 | Bool | Use initial condition marker for second entity for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint when True. If False, initial condition information is defined with respect to the reference marker. | True |
ic_use_xyz | Bool | Denotes if the displacement initial conditions are to be used for the entity for type PointToCurveJoint or PointToSurfaceJoint. | False |
ic_use_vel | Bool | Denotes if the velocity initial conditions are to be used for the point for type PointToCurveJoint or PointToSurfaceJoint. | False |
ic_x_disp | Double | The value of the initial displacement of the contact point in the icm_1 x direction. | 0 |
ic_y_disp | Double | The value of the initial displacement of the contact point in the icm_1 y direction. | 0 |
ic_z_disp | Double | The value of the initial displacement of the contact point in the icm_1 z direction. | 0 |
ic_vel | Double | The value of the initial velocity of point for type PointToCurveJoint or PointToSurfaceJoint. | 0 |
ic_use_xyz1 | Bool | Denotes if the displacement initial conditions are to be used for the entity 1 for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | False |
ic_use_vel1 | Bool | Denotes if the velocity initial conditions are to be used for the contact point o body1 for type CurveToCurveJoint. | False |
ic_x_disp1 | Double | The value of the initial displacement of the point of contact in the icm x direction on the curve for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | 0 |
ic_y_disp1 | Double | The value of the initial displacement of the point of contact in the icm y direction on the curve for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | 0 |
ic_z_disp1 | Double | The value of the initial displacement of the point of contact in the icm z direction on the curve for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | 0 |
ic_vel1 | Double | The value of the initial velocity of the point of contact on body 1. Applicable for type CurveToCurveJoint. | 0 |
ic_use_xyz2 | Bool | Denotes if the displacement initial conditions are to be used for the contact point on body_2. | False |
ic_use_vel2 | Bool | Denotes if the velocity initial conditions are to be used for the contact point on body_2. | False |
ic_x_disp2 | Double | The value of the initial displacement of the point of contact in the icm x direction on the curve/surface for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | 0 |
ic_y_disp2 | Double | The value of the initial displacement of the point of contact in the icm y direction on the curve/surface for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | 0 |
ic_z_disp2 | Double | The value of the initial displacement of the point of contact in the icm z direction on the curve/surface for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. | 0 |
ic_vel2 | Double | The value of the initial velocity of the point of contact on body 2. Applicable for type CurveToCurveJoint. | 0 |
Instances
Instance | Type | Description |
icm | Marker | Initial condition information is defined with respect to this marker when ic_use_icm is True. Applicable for type PointToCurveJoint or PointToSurfaceJoint. |
icm1 | Marker | Initial condition information is defined with respect to this marker for first entity in the joint when ic_use_icm1 is True. Applicable for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. |
icm2 | Marker | Initial condition information is defined with respect to this marker for second entity in the joint when ic_use_icm2 is True. Applicable for type CurveToCurveJoint, CurveToSurfaceJoint or SurfaceToSurfaceJoint. |
i | Marker | The 'i' marker in the case of a compliant joint. |
j | Marker | The 'j' marker in the case of a compliant joint. |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
3. Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
Methods
- getAssociatedGraphics()
Get all the graphics that are associated with this object.
Returns:
List of all graphic associated with this joint.
Return type:
(list)
Constraint Mate
Class ConstraintMate()
ConstraintMate(parent='MODEL', name='ConstraintMate_n', label='ConstraintMate_n',
active=True, b1=None, b2=None, origin=None, origin2=None, type1='DISTANCE', type2='POINT',
type3='POINT', distance=0, iradius=0, jradius=0, height=0, align_meth1='VECTOR',
align_pt1=None, align_vec1=None, align_meth2='Point', align_pt2=None, align_vec2=None)
Creates a primitive geometry based general mating constraint.
Keyword Arguments
name | String | The variable name. | ConstraintMate_n, for next available integer n. |
label | String | The descriptive label. | ConstraintMate_n, for next available integer n. |
active | Bool | Used to activate or deactivate this entity. | True |
b1 | Body | The first connecting body of the joint. | None |
b2 | Body | The second connecting body of the joint. | None |
origin | Point | Origin of geometry on the first body. | None |
origin2 | Point | Origin of geometry on the second body. | None |
type1 | Enum | One of DISTANCE, COINCIDENT or TANGENT. | DISTANCE |
type2 | Enum | One of POINT, SPHERE, LINE, CYLINDER or PLANE. | POINT |
type3 | Enum | One of POINT, SPHERE, LINE, CYLINDER, PLANE or CONE. | POINT |
distance | Double | The distance value. | 0 |
iradius | Double | The radius of the CYLINDER of the first geometry | 0 |
jradius | Double | The radius of the CYLINDER of the second geometry or the base radius of the CONE of the second geometry. | 0 |
height | Double | The height of the CONE of the second geometry. | 0 |
align_meth1 | MultiRef | One of POINT or VECTOR. * align_pt1 (Point) - Point defining orientation geometry at first location. | None |
align_vec1 | Vector | Vector defining orientation geometry at first location. | None |
align_meth2 | MultiRef | One of POINT or VECTOR. | ‘Point' |
align_pt2 | Point | Point defining orientation geometry at second location. | None |
align_vec2 | Vector | Vector defining orientation geometry at second location. | None |
Notes
Methods
Returns:
Return type:
(list)
Constraint Mate Pair
Class ConstraintMatePair()
class ConstraintMatePair(parent='MODEL', name='ConstraintMatePair_n',
label='ConstraintMatePair_n', active=True, sym='NONE')
ConstraintMate pair containing left and right instances of singles.
Keyword Arguments
name | String | The variable name. | ConstraintMatePair_n, for next available integer n. |
label | String | The descriptive label. | ConstraintMatePair_n, for next available integer n. |
active | Bool | Defines if entity is activated when True or deactivated when False. | True |
sym | Enum | The symmetry of pair entity. Takes values 'LEFT' for left entity as master, 'RIGHT' for right entity as master or 'NONE' when it is not symmetric. | LEFT |
Instances
l | Point | The left ConstraintMate. |
r | Point | The right ConstraintMate. |
Examples
Create an advanced joint and modify its attribute properties
>>> # Import mview module
>>> from hw import mview
>>> # Create Point for Advanced joint
>>> p1 = mview.Point(x = 0.0,y = 25.0,z = 0.0)
>>> # Create a body for Advanced joint
>>> b1 = mview.Body(name = "b_PTCV",usecm = True)
>>> b1.cg = p1
>>> # Create a Curve for PTCV joint
>>> c1 = mview.Curve(name = "c1",type = "3DCARTESIAN",x_type = "VALUE",y_type = "VALUE",z_type = "VALUE")
>>> c1.x_value = [0,10,20,30,40,50]
>>> c1.y_value = [25,30,35,40,45,50]
>>> c1.z_value = [0,0,0,0,0,0]
>>> # Create an Advanced joint of PTCV type
>>> adv1 = mview.AdvJoint(name = "adv1",type = "PointToCurveJoint")
>>> # Set a single attribute at a time
>>> adv1.origin = p1
>>> # Set multiple values at once
>>> adv1.setValues(b1 = b1,b2 = "adv1.rm.body")
>>> # Set other attributes of Advanced joint
>>> adv1.crv = c1
>>> adv1.rm = 'Global_Frame'
>>> # Create an Outline graphic for visualizing the PTCV joint
>>> o1 = mview.Outline(name = "visual",itype = "ADV_JOINT_CRV")
>>> o1.advjoint = aj_PTCV
