Graphic
File Graphic
Class FileGraphic()
FileGraphic(parent='MODEL', name='FileGraphic_n',
label='FileGraphic_n', active=True, wire_mode='OFF', shade_mode='USE_MATERIAL', is_material_inside=True,
refinement_level=3, body=None, filename='', reader='', avail_comp_list=[], sel_comp_list=[],
mesh_coarsening_level='NONE', align_meth1='MARKER', align_b1=None,
align_mrk1='Global_Frame', align_p1=None, align_p2=None, align_p3=None, origin_x=0,
origin_y=0, origin_z=0, psi=0, theta=0, phi=0, scale_x=1, scale_y=1, scale_z=1)
Graphic defined in a file.
Keyword Arguments
Argument | Data Type | Description | Default |
name | String | The variable name. | FileGraphic_n, for next available integer n. |
label | String | The descriptive label. | FileGraphic_n, for next available integer n. |
parent | Object | The parent. | MODEL |
active | Bool | Used to activate or deactivate this entity. | True |
wire_mode | Enum | Wireframe representation. One of WIREFRAME, FEATURE_LINES, FREE_EDGE_LINES or OFF. Defaults to ‘OFF'. * shade_mode (Enum) - Shaded mode representation. One of: OPAQUE, OFF, USE_MATERIAL or TRANSPARENT. | ‘USE_MATERIAL' |
is_material_inside | Bool | True if the material inside is solid, false otherwise. Applies to contact simulations. | True |
refinement_level | Int | The mesh density of primitive solids. Applies to contact simulations. | 3 |
body | Body | The associated body. | None |
filename | File | The absolute file path. | ‘' |
reader | File | Need input. | ‘' |
avail_comp_list | list | The available components in graphic file. | [] |
sel_comp_list | list | The selected graphic components from avail_comp_list. Empty, if all selected. | [] |
mesh_coarsening_level | Enum | Need input. One of AGGRESSIVE, AVERAGE, CONSERVATIVE or NONE. | ‘NONE' |
align_meth1 | Enum | Alignment method. One of PART, MARKER, AUTO_POS, AUTO_POSORIENT or AUTO_POSORIENTSCALE. | MARKER |
align_b1 | Body | Reference body when align_meth1 is PART. | None |
align_mrk1 | Marker | Reference marker when align_meth1 is MARKER. | ‘Global_Frame' |
align_p1 | Point | Locator point 1 when align_meth1 is AUTO_POS, AUTO_POSORIENT or AUTO_POSORIENTSCALE. | None |
align_p2 | Point | Locator point 2 when align_meth1 is AUTO_POS, AUTO_POSORIENT or AUTO_POSORIENTSCALE. | None |
align_p3 | Point | Locator point 3 when align_meth1 is AUTO_POS, AUTO_POSORIENT or AUTO_POSORIENTSCALE. | None |
origin_x | Double | The x coordinate of the graphic origin with respect to ref_body or ref_marker specified. | 0 |
origin_y | Double | The y coordinate of the graphic origin with respect to ref_body or ref_marker specified. | 0 |
origin_z | Double | The z coordinate of the graphic origin with respect to ref_body or ref_marker specified. | 0 |
psi | Double | The psi euler angle(z-x'-z'') in radians with respect to align_b1 or align_mrk1. | 0 |
theta | Double | The theta euler (z-x'-z'') in radians with respect to align_b1 or align_mrk1. | 0 |
phi | Double | The phi euler (z-x'-z'') in radians with respect to align_b1 or align_mrk1. | 0 |
scale_x | Double | The x scale factor. | 1 |
scale_y | Double | The y scale factor. | 1 |
scale_z | Double | The z scale factor. | 1 |
Instances
Instance | Type | Description |
color_mat | ColorMat | The color_mat instance to modify color properties. |
Notes
Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
Methods
- setValue(name, value, updatePanel=True)
Sets value of an attribute.
Parameters:
name str Name of the attribute. value ** Value of the attribute to be set. Returns:
Returns True if the value was successfully set, else False.
Return type:
Bool
Examples
Create and modify attributes of a File graphic.
>>> from hw import mview
>>> f1 = mview.FileGraphic(name = 'f1')
>>> #Select the file and components from it
>>> f1.filename = r"C:\Users\user\Desktop\graphic.h3d"
>>> f1.sel_comp_list = ["Part2","Part9"]
>>> f1.body = mview.getModel().B_Ground
>>> #GEt values of attributes
>>> f1.mesh_coarsening_level
'NONE'
>>> #Set multiple values at once (location properties here)
>>> c1.setValues(origin_x = 10,theta = 3.14,scale_z = 1.5)
>>> f1.mesh_coarsening_level = 'Conservative'
>>> e1.color_mat = "mat_green"
>>> #Change alignment method
>>> f1.align_meth1 = 'PART'
CAD Graphic
Class CADGraphic()
CADGraphic(parent='MODEL', name='CADGraphic_n', label='CADGraphic_n', active=True,
wire_mode='OFF', shade_mode='USE_MATERIAL', is_material_inside=True, body=None, filename='',
avail_comp_list=[], sel_comp_list=[], align_meth1='MARKER', align_b1=None,
align_mrk1='Global_Frame', origin_x=0, origin_y=0, origin_z=0, psi=0, theta=0, phi=0,
The CAD graphic.
Keyword Arguments
name | String | The variable name. | CADGraphic_n, for next available integer n. |
label | String | The descriptive label. | CADGraphic_n, for next available integer n. |
wire_mode | Enum | Wireframe representation. One of WIREFRAME, FEATURE_LINES, FREE_EDGE_LINES or OFF. Deafults to ‘OFF'. * shade_mode (Enum) - Shaded mode representation. One of: OPAQUE, OFF, USE_MATERIAL or TRANSPARENT. | ‘USE_MATERIAL' |
is_material_inside | Bool | True if the material inside is solid, false otherwise. Applies to contact simulations. | None |
filename | File | The absolute file path. | None |
sel_comp_list | list | The selected graphic components. Empty, if all selected. | [] |
avail_comp_list | list | The available components. | [] |
fidelity | Double | Level of fineness of the geometry displayed as tessellated mesh. Controls the mesh refinement. Range is 1 and 10 (with 1(coarse) and 10(fine) ). Applies to mesh visualization when solvermode is motionsolve. | 0 |
align_meth1 | Enum | Alignment method. Indicates whether the graphic is located with respect to body reference frame or marker. If PART is used, it indicates that the graphic has to be positioned using a body. If MARKER is used, it indicates that the graphic is positioned using a marker. | ‘MARKER' |
align_mrk1 | Marker | Reference marker when align_meth1 is MARKER. * origin_x (Double) - The x coordinate of the graphic origin with respect to align_b1 or align_mrk1. | 0 |
origin_y | Double | The y coordinate of the graphic origin with respect to align_b1 or align_mrk1. | 0 |
origin_z | Double | The z coordinate of the graphic origin with respect to align_b1 or align_mrk1. | 0 |
psi | Double | The psi Euler angle (z-x'-z'') in radians with respect to align_b1 or align_mrk1. | 0 |
theta | Double | The theta Euler angle (z-x'-z'') in radians with respect to align_b1 or align_mrk1. | 0 |
phi | Double | The phi Euler angle (z-x'-z'') in radians with respect to align_b1 or align_mrk1. | 0 |
Instances
Readonly Properties:
mass | double | The mass. | |
cm_x | double | The x coordinate of center of mass with respect to the global coordinate system. | |
cm_y | double | The y coordinate of center of mass with respect to the global coordinate system. | |
cm_z | double | The z coordinate of center of mass with respect to the global coordinate system. | |
Ixx | double | The Ixx moment of inertia with respect to the global coordinate system. | |
Ixy | double | The Ixy moment of inertia with respect to the global coordinate system. | |
Ixz | double | The Ixz moment of inertia with respect to the global coordinate system. | |
Iyx | double | The Iyx moment of inertia with respect to the global coordinate system. | |
Iyy | double | The Iyy moment of inertia with respect to the global coordinate system. | |
Iyz | double | The Iyz moment of inertia with respect to the global coordinate system. | |
Izx | double | The Izx moment of inertia with respect to the global coordinate system. | |
Izy | double | The Izy moment of inertia with respect to the global coordinate system. | |
Izz | double | The Izz moment of inertia with respect to the global coordinate system. |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
3. Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
4. Readonly Properties cannot be modified.
Methods
- setValue(name, value)
Parameters:
Returns True if the value was successfully set else False.
Return type:
Bool
Examples
Create and modify attributes of a CAD graphic.
>>> c1 = mview.CADGraphic(name = 'cad1')
>>> c1.filename = r"C:\Users\user\Desktop\cadfile.step"
>>> c1.sel_comp_list = ["Part1","Part3"]
>>> #Set material property of graphic
>>> c1.materialprop = "propmat_aluminum"
>>> c1.color_mat = "mat_purple"
>>> #Set graphic alignment
>>> m1 = mview.Marker(name = 'align')
>>> c1.align_mrk1 = m1
>>> #Set mesh coarseness
>>> c1.fidelity = 7
>>> c1.align_meth1 = 'PART'
>>> c1.align_b1 = 'B_Ground'
Box
Class Box()
Box(parent='MODEL', name='Box_n', label='Box_n', active=True, itype='FACE',
lenghtx=10, lengthy=10, body=None, origin=None, origin2=None, ornt_meth='TWOAXES', ornt_dir1='Z',
align_meth1='Point', align_pt1=None, align_vec1=None, ornt_dir2='X', align_meth2='Vector',
align_pt2=None, align_vec2=None)
Create a Box graphic.
Keyword Arguments
Argument | Data Type | Description | Data Type |
name | String | The variable name. | Box_n, for next available integer n. |
label | String | The descriptive label. | Box_n, for next available integer n. |
itype | Enum | Type type. One of CENTER, CORNER or FACE. | FACE |
lengthx | Double | The length in the x direction. | 10 |
lengthy | Double | The length in the y direction. | 10 |
lengthz | Double | The length in the z direction. Does not apply for a FACE box type. | 10 |
origin | Point | The origin of a CORNER or CENTER type box. | None |
origin2 | Point | The location of other end of a FACE type box. | None |
ornt_meth | Enum | Orientation method. One of TWOAXES, ONEAXIS or ANGLES. | TWOAXES |
ornt_dir1 | Enum | Orientation direction for axis 1. One of X, Y or Z. | Z |
align_meth1 | Enum | Alignment method for axis 1. One of Point or Vector. | Point |
align_pt1 | Point | Reference point for aligning axis 1 when align_meth1 is Point. | None |
align_vec1 | Vector | Reference vector for aligning axis 1 when align_meth1 is Vector. | None |
ornt_dir2 | Enum | Orientation direction for axis 2. One of X, Y or Z. | X |
align_meth2 | Enum | Alignment method for axis 2. One of Point or Vector. | Vector |
align_pt2 | Point | Reference point for aligning axis 2 when align_meth2 is Point. | None |
align_vec2 | Vector | Reference vector for aligning axis 2 when align_meth2 is Vector. | None |
Instances
Readonly Properties
Argument | Data Type | Description | |
Notes
Examples
Create and modify attributes of a Box graphic.
>>> bx1 = mview.Box(name = 'Box1')
>>> #Set references for Box graphic
>>> b1 = mview.Body(label = 'BodyForGraphic')
>>> bx1.body = b1
>>> bx1.origin = mview.getModel().P_Global_Origin
>>>#Change the input type of Box
>>> bx1.itype = 'CORNER'
>>> #Get attribute values
>>> bx1.ornt_dir1
'Z'
>>> bx1.setValues(ornt_dir1 = 'X',align_meth1 = 'VECTOR',lengthz = 5)
>>> bx1.align_vec1 = 'V_Global_X'
>>> bx1.ornt_dir2 = 'Z'
>>> #Get and set material property of BoxPair Graphic
>>> bx1.materialprop.name
'propmat_steel'
>>> bx1.materialprop = "propmat_bronze"
>>> bx1.refinement_level = 5
>>> #Create a BoxPair inside a System and set dimensions
>>> sys = mview.System(name = 'System1')
>>> bx2 = mview.BoxPair(parent = sys,itype = 'CENTER')
>>> bx2.itype = 'CENTER'
>>> bx2.body = b1
>>> p1 = mview.PointPair(y = 100)
>>> bx2.origin = p1
>>> bx2.align_meth1='VECTOR'
>>> bx2.align_vec1 = 'V_Global_X'
>>> bx2.l.lengthx = 30
>>> #Set parametric value
>>> bx2.l.lengthz = "Box1.r1+10"
>>> #Change input type of BoxPair
>>> bx2.itype = 'FACE'
>>> bx2.l.origin2 = 'P_Global_Origin'
Box Pair
Class BoxPair()
BoxPair(parent='MODEL', name='BoxPair_n', label='BoxPair_n', active=True, sym='NONE')
Box pair containing left and right instances of singles.
Keyword Arguments:
name | String | The variable name. | BoxPair_n, for next available integer n. |
label | String | The descriptive label. | BoxPair_n, for next available integer n. |
active | Bool | Defines if entity is activated when True or deactivated when False. | True |
sym | Enum | The symmetry of pair entity. Takes values 'LEFT' for left entity as master, 'RIGHT' for right entity as master or 'NONE' when it is not symmetric. | NONE |
Instances
l | Point | The left box. |
r | Point | The right box. |
Notes
Sphere
Class Sphere()
Sphere(parent='MODEL', name='Sphere_n', label='Sphere_n', active=True,
body=None, origin=None, radius=10)
The sphere graphic.
Keyword Arguments:
name | String | The variable name. | Sphere_n, for next available integer n. |
label | String | The descriptive label. | Sphere_n, for next available integer n. |
origin | Point | The center. | None |
radius | Double | The radius. | 10 |
Instances
Notes
4. Read only Properties cannot be modified.
Examples
Create and modify attributes of a Sphere graphic.
>>> s1 = mview.Sphere(name='s1')
>>> b1 = mview.Body(name='b1',mass=10)
>>> s1.setValues(body=b1,origin='P_Global_Origin')
>>> #Get and set values of attributes
>>> s1.radius
10.0
>>> s1.radius = 25
>>> e1.color_mat = "mat_red"
>>> e2.materialprop = "propmat_titanium"
>>> #Create a SpherePair in System and set properties
>>> sys = mview.System(name='sys')
>>> s2 = mview.SpherePair(parent=sys,name='s2')
>>> p2 = mview.PointPair(parent=sys,y=25)
>>> s2.body = 'B_Ground'
>>> s2.origin = p2
>>> s2.radius = "MODEL.s1.radius/2"
Sphere Pair
Class SpherePair()
SpherePair(parent='MODEL', name='SpherePair_n', label='SpherePair_n', active=True, sym='NONE')
Sphere pair containing left and right instances of singles.
Keyword Arguments:
name | String | The variable name. | SpherePair_n, for next available integer n. |
label | String | The descriptive label. | SpherePair_n, for next available integer n. |
Instances
l | Point | The left sphere. |
r | Point | The right sphere. |
Notes
Cylinder
Class Cylinder()
Cylinder(parent='MODEL', name='Cylinder_n', label='Cylinder_n', active=True, body=None,
origin=None, align_meth1='Point', align_pt1=None, align_vec1=None, r1=10, r2=10, length=0,
offset=0, useautolen=True, cap_flag='CAPBOTH')
Cylinder graphic.
Keyword Arguments
name | String | The variable name. | Cylinder_n, for next available integer n. |
label | String | The descriptive label. | Cylinder_n, for next available integer n. |
active | Boolean | Used to activate or deactivate this entity. | True |
origin | Point | Location of one end. | None |
align_meth1 | Enum | Alignment method. One of POINT or VECTOR. | ‘Point' |
align_pt1 | Point | Reference point when align_meth1 is POINT. | None |
align_vec1 | Vector | Reference vector when align_meth1 is VECTOR. | None |
r1 | Double | The radius at one end. | 10 |
r2 | Double | The radius at one end. | 10 |
length | Double | The length of cylinder. | 0 |
offset | Double | The distance by which the actual origin of the cylinder is offset from origin specified. | 0 |
useautolen | Bool | Use auto length for the cylinder. Can be used when align_meth1 is POINT. | True |
cap_flag | Enum | End capping method. One of CAPNONE, CAPBOTH, CAPBEGIN or CAPEND. | ‘CAPBOTH' |
Instances
Izz | double | The Izz moment of inertia with respect to the global coordinate system. | |
autolen | Double | Calculated length of cylinder when useautolen is True. |
Notes
Examples
Create and modify attributes of a Cylinder graphic.
>>> c1 = mview.Cylinder(name='c1')
>>> #Set cylinder graphic references
>>> b1 = mview.Body(name='BodyForGraphic')
>>> c1.body = b1
>>> c1.origin = 'P_Global_Origin'
>>> c1.color_mat = "mat_red"
>>> #Get values of attributes
>>> c1.align_meth1
'Point'
>>> #Set alignment properties of graphic
>>> c1.align_meth1 = 'VECTOR'
>>> c1.align_vec1 = mview.getModel().V_Global_X
>>> #Create a CylinderPair inside a System and set properties
>>> c2 = mview.CylinderPair(parent=sys,name='c2')
>>> c2.setValues(body=b1,origin='P_Global_Origin')
>>> sys2 = mview.System(name = 'System2')
>>> p1 = mview.Point(parent='System2',name='p_1',label='PointForAlignment')
>>> c2.align_pt1 = getModel().System2.p_1
>>> p1 = mview.PointPair(label='PointForAlignment',y=100)
>>> c2.origin = p1
>>> c2.align_pt1 = 'P_Global_Origin'
>>> c2.materialprop = "propmat_copper"
>>> e1.color_mat = "mat_yellow"
>>> c2.refinement_level = 5
>>> #Set cylinder dimensions
>>> c2.l.autolen = False
>>> c2.l.length = 70
>>> c2.l.r1 = 25
>>> #Set parametric values
>>> c2.l.r2 = "c1.r1*1.5"
Cylinder Pair
Class CylinderPair()
CylinderPair(parent='MODEL', name='CylinderPair_n', label='CylinderPair_n',
Cylinder pair containing left and right instances of singles.
Keyword Arguments
name | String | The variable name. | CylinderPair_n, for next available integer n. |
label | String | The descriptive label. | CylinderPair_n, for next available integer n. |
Instances
l | Point | The left cylinder. |
r | Point | The right cylinder. |
Notes
Ellipsoid
Class Ellipsoid()
Ellipsoid(parent='MODEL', name='Ellipsoid_n', label='Ellipsoid_n', active=True, body=None,
origin=None, ornt_meth='TWOAXES', ornt_dir1='Z', align_meth1='POINT', align_pt1=None,
align_vec1=None, ornt_dir2='X', align_meth2='VECTOR', align_pt2=None, align_vec2=None,
rX=10, rY=5, rZ=2.5)
Ellipsoid graphic.
Keyword Arguments
name | String | The variable name. | Ellipsoid_n, for next available integer n. |
label | String | The descriptive label. | Ellipsoid_n, for next available integer n. |
ornt_meth | Enum | Orientation method. One of TWOAXES, ONEAXIS or ANGLES. | ‘TWOAXES' |
ornt_dir1 | Enum | Orientation direction for axis 1. One of X, Y or Z. | ‘Z' |
align_meth1 | Enum | Alignment method for axis 1. One of POINT or VECTOR. | ‘POINT' |
ornt_dir2 | Enum | Orientation direction for axis 2. One of X, Y or Z. | ‘X' |
align_meth2 | Enum | Alignment method for axis 2. One of POINT or VECTOR. | ‘VECTOR' |
align_pt2 | Point | Reference point when align_meth2 is POINT. | None |
align_vec2 | Vector | Reference vector when align_meth2 is VECTOR. | None |
rX | Double | The radius in x direction. | 10 |
rY | Double | The radius in y direction. | 5 |
rZ | Double | The radius in z direction. | 2.5 |
Instances
Readonly Properties
Notes
Examples
Create and modify attributes of an Ellipsoid graphic.
>>> e1 = mview.Ellipsoid(name = 'e1')
>>> p1 = mview.Point(name = "p_1")
>>> e1.setValues(body = 'B_Ground',origin = p1)
>>> e1.align_pt1 = 'P_Global_Origin'
>>> e1.rX = 20
>>> e1.rY = 12
>>> #Create and modify an EllipsoidPair in an Analysis
>>> a1 = mview.Analysis(active = True)
>>> e2 = mview.EllipsoidPair(parent = a1,name = 'e2')
>>> e2.setValues(body = 'B_Ground',align_pt1 = 'P_Global_Origin')
>>> p2 = mview.PointPair(parent = a1,name = "p_2",y = 50)
>>> e2.origin = p2
>>> e2.ornt_dir1 = 'X'
>>> e2.ornt_dir2 = 'Y'
>>> e2.materialprop = "propmat_bronze"
>>> e2.refinement_level = 5
>>> e2.rZ = "p_2.l.y-25"
Ellipsoid Pair
Class EllipsoidPair()
EllipsoidPair(parent='MODEL', name='EllipsoidPair_n', label='EllipsoidPair_n',
Ellipsoid pair containing left and right instances of singles.
Keyword Arguments
name | String | The variable name. | EllipsoidPair_n, for next available integer n. |
label | String | The descriptive label. | EllipsoidPair_n, for next available integer n. |
Instances
l | Point | The left ellipsoid. |
r | Point | The right ellipsoid. |
Notes
Outline
Class Outline()
class Outline(parent='MODEL', name='Outline_n', label='Outline_n', active=True, wire_mode='OFF',
shade_mode='USE_MATERIAL', is_material_inside=True, refinement_level=3, itype='MARKER',
markers=None, bodies=None, points=None, pbeam=None, advjoint=None, marker='Global_Frame', body=None)
Outline graphic.
Keyword Arguments
name | String | The variable name. | Outline_n, for next available integer n. |
label | String | The descriptive label. | Outline_n, for next available integer n. |
wire_mode | Enum | Wireframe representation. One of WIREFRAME, FEATURE_LINES, FREE_EDGE_LINES or OFF. Deafults to OFF. * shade_mode (Enum) - Shaded mode representation. One of: OPAQUE, OFF, USE_MATERIAL or TRANSPARENT. | USE_MATERIAL |
itype | Enum | Type of outline graphic. One of MARKER, BODYPT, POLYBEAM or ADV_JOINT_CRV. | ‘MARKER' |
markers | *Marker list* | List of markers when itype is MARKER. | None |
bodies | *Body list* | List of bodies when itype is BODYPT. | None |
points | *Point list* | List of points when itype is BODYPT. | None |
pbeam | PolyBeam | The associated polybeam when itype is POLYBEAM. | None |
advjoint | AdvJoint | The associated advanced joint when itype is ADV_JOINT_CRV. | None |
cur_sel | Enum | Curve number when advjoint is of type CurveToCurveJoint. One of CURVE1 or CURVE2. | CURVE1 |
marker | Marker | The associated marker when itype is MARKER. | ‘Global_Frame' |
body | Body | The associated body when itype is BODYPT. | None |
Instances
Notes
Methods
- getBody()
Get the body that this graphic is for: MARKER - first
marker body BODYPT - first body POLYBEAM - first
beam body (body0) ADV_JOINT_CRV - b1
Examples
Create and modify attributes of an Outline graphic.
>>> o1 = mview.Outline(name='o1',itype = 'MARKER')
>>> #Creating a number of markers and points with different coordinates
>>> for i in range(5):
... m = mview.Marker()
>>> for i in range(5):
... p = mview.Point(x = i, y = 2*i)
>>> allmarkers = mview.getModel().getChildren(type = 'Marker')
>>> allpoints = mview.getModel().getChildren(type = 'Point')
>>> #Setting all points as origins to all markers
>>> for i in range(len(allmarkers)):
... allmarkers[i].origin = allpoints[i]
>>> #Using the newly created markers as reference for Outline graphic
>>> o1.markers = allmarkers
>>> #Chaning the input type for the Outline graphic
>>> o1.itype = 'BODYPT'
>>> for i in range(5):
... b = mview.Body()
>>> allbodies = mview.getModel().getChildren(type='Body')
>>> #Set multiple values as once
>>> o1.setValues(bodies = allbodies,points = allpoints)
>>> #Changing input type for the Outline graphic
>>> o1.itype = 'POLYBEAM'
>>> poly = mview.PolyBeam()
>>> o1.pbeam = poly
>>> o1.itype = 'ADV_JOINT_CRV'
>>> adv = mview.AdvJoint()
>>> o1.advjoint = adv
Curve Graphic
Class CurveGraphic()
CurveGraphic(parent='MODEL', name='CurveGraphic_n', label='CurveGraphic_n', active=True,
wire_mode='OFF', shade_mode='USE_MATERIAL', is_material_inside=True, refinement_level=3,
ptype='BODYPT', ref_marker='Global_Frame', body='B_Ground', origin='P_Global_Origin', crv=None)
Curve graphic.
Keyword Arguments
name | String | The variable name. | CurveGraphic_n, for next available integer n. |
label | String | The descriptive label. | CurveGraphic_n, for next available integer n. |
wire_mode | Enum | Wireframe representation. One of WIREFRAME, FEATURE_LINES, FREE_EDGE_LINES or OFF. Deafults to OFF. * shade_mode (Enum) - Shaded mode representation. One of OPAQUE, OFF, USE_MATERIAL or TRANSPARENT. | USE_MATERIAL |
ptype | Enum | The parent type. One of MARKER or BODYPT. | ‘BODYPT' |
ref_marker | Marker | Reference marker when ptype is MARKER. | ‘Global_Frame' |
body | Body | The associated body. | ‘B_Ground' |
origin | Point | Origin when ptype is BODYPT. | ‘P_Global_Origin' |
crv | Curve | Curve associated with the graphic. | None |
Instances
int_marker | Marker | Marker when ptype is BODYPT. |
Notes
Methods
- getBody()
If the graphic is using markers, get the body from the first marker otherwise, get return the body.
Parameters:
Return type:
Bool
Tube
Class Tube()
Tube(parent='MODEL', name='Tube_n', label='Tube_n', active=True, wire_mode='OFF',
shade_mode='USE_MATERIAL', is_material_inside=True, refinement_level=3, pbeam=None)
Tube graphic.
Keyword Arguments
name | String | The variable name. | Tube_n, for next available integer n. |
label | String | The descriptive label. | Tube_n, for next available integer n. |
wire_mode | Enum | Wireframe representation. One of WIREFRAME, FEATURE_LINES, FREE_EDGE_LINES or OFF. | OFF |
shade_mode | Enum | Shaded mode representation. One of OPAQUE, OFF, USE_MATERIAL or TRANSPARENT. | USE_MATERIAL |
pbeam | PolyBeam | The associated polybeam. | None |
Instances
OD | Double | The outer diameter. | |
ID | Double | The inner diameter. |
Notes
Methods
- getBody()
Get the body that this graphic is for.
Returns:
Returns the body associated with this graphic.
Return type:
Body
Spring Graphic
Class SpringGraphic()
SpringGraphic(parent='MODEL', name='SpringGraphic_n', label='SpringGraphic_n', active=True,
spdp=None, p1=None, p2=None, radiys=5, num_coils=10)
Spring graphic.
Keyword Arguments
name | String | The variable name. | SpringGraphic_n, for next available integer n. |
label | String | The descriptive label. | SpringGraphic_n, for next available integer n. |
wire_mode | Enum | Wireframe representation. One of: WIREFRAME, FEATURE_LINES, FREE_EDGE_LINES or OFF. | OFF |
shade_mode | Enum | Shaded mode representation. One of: OPAQUE, OFF, USE_MATERIAL or TRANSPARENT. | USE_MATERIAL |
spdp | SpringDamper | The associated springdamper. | None |
p1 | Point | One of the connecting points. | None |
p2 | Point | The other connecting point. | None |
radius | Double | The radius. | 5 |
num_coils | Double | The number of coils. | 10 |
Instances
Notes
Methods
- getAssociatedObjects()
Get the body and the spring damper associated with this spring graphic.
Returns:
A list of body and spring damper associated with this spring graphic.
Return type:
list
- getBody()
Get the b1 used by the spring damper associated with this spring graphic.
Returns:
Body(b1) associated with the spring damper of this spring graphic.
Return type:
body (Body)
Examples
Create and modify attributes of a Spring graphic.
>>> sg = mview.SpringGraphic(name = 'sg1')
>>> p1 = mview.Point(name = 'startpoint', x = 60)
>>> #Create a SpringDamper for the graphic
>>> spdp = mview.SpringDamper(name = 'spdp')
>>> #Set the attributes for the SpringGraphic
>>> sg.spdp = spdp
>>> sg.p1 = p1
>>> sg.p2 = 'P_Global_Origin'
>>> sg.setValues(radius = 4,num_coils = 20)
>>> sg.color_mat = "mat_goldenrod5"
>>> #Creating SpringGraphic paired object
>>> sg2 = mview.SpringGraphicPair(name='sg2')
>>> spdp2 = mview.SpringDamperPair(name='spdp2')
>>> sg2.spdp = spdp2
>>> p_start = mview.PointPair(y = 50)
>>> p_end = mview.PointPair(x = 100, y = 50)
>>> sg2.setValues(p1=p_start,p2=p_end)
Spring Graphic Pair
Class SpringGraphicPair()
SpringGraphicPair(parent='MODEL', name='SpringGraphicPair_n', label='SpringGraphicPair_n',
SpringGraphic pair containing left and right instances of singles.
Keyword Arguments
name | String | The variable name. | SpringGraphicPair_n, for next available integer n. |
label | String | The descriptive label. | SpringGraphicPair_n, for next available integer n. |
Instances
l | Point | The left SpringGraphic. |
r | Point | The right SpringGraphic. |
Notes
Tire
Class Tire()
Tire(parent='MODEL', name='Tire_n', label='Tire_n', active=True, wire_mode='OFF',
shade_mode='USE_MATERIAL', is_material_inside=True, refinement_level=3, tirespec='P215/70*15',
body=None, origin=None, align_meth1='Point', align_p1=None, align_vec1=None)
Tire graphic.
Keyword Arguments
name | String | The variable name. | Tire_n, for next available integer n. |
label | String | The descriptive label. | Tire_n, for next available integer n. |
tirespec | String | Tire and Rim Association (T&RA) specification. | ‘P215/70*15' |
origin | Point | Location of the tire. | None |
align_meth1 | MultiRef | Alignment method. One of Point or Vector. | ‘Point' |
align_pt1 | Point | Reference point when align_meth1 is Point. | None |
align_vec1 | Vector | Reference vectorwhen align_meth1 is Vector. | None |
Instances
Notes
Tire Pair
Class TirePair()
TirePair(parent='MODEL', name='TirePair_n', label='TirePair_n', active=True, sym='NONE')
Tire pair containing left and right instances of singles.
Keyword Arguments
name | String | The variable name. | TirePair_n, for next available integer n. |
label | String | The descriptive label. | TirePair_n, for next available integer n. |
Instances
l | Point | The left Tire. |
r | Point | The right Tire. |
Notes
Deformable Curve Graphic
Class DeformableCurveGraphic()
DeformableCurveGraphic(parent='MODEL', name='DeformableCurveGraphic_n', label='DeformableCurveGraphic_n',
active=True, wire_mode='OFF', shade_mode='USE_MATERIAL', is_material_inside=True, refinement_level=3,
defcurve=None, num_segs=100)
Deformable curve graphic.
Keyword Arguments
name | String | The variable name. | DeformableCurveGraphic_n, for next available integer n. |
label | String | The descriptive label. | DeformableCurveGraphic_n, for next available integer n. |
defcurve | DeformableCurve | The associated deformable curve. | None |
num_segs | Int | The number of segments. | 100 |
Instances
Instance | Type | Description | |
Notes
Methods
- Return the body and the deformable curve.
- getBody()
If the selected DeformableCurve is using markers, return the body used by the first marker. If it is using bodies and points, return the first body.
Deformable Surface Graphic
Class DeformableSurfaceGraphic()
DeformableSurfaceGraphic(parent='MODEL', name='DeformableSurfaceGraphic_n', label='DeformableSurfaceGraphic_n',
defsurf=None, num_u_segs=100, num_v_segs=100)
Deformable surface graphic.
Keyword Arguments
name | String | The variable name. | DeformableSurfaceGraphic_n, for next available integer n. |
label | String | The descriptive label. | DeformableSurfaceGraphic_n, for next available integer n. |
defsurf | DeformableSurface | The associated deformable surface. | None |
num_u_segs | Int | The number of row segments. Defaults to 100. * num_v_segs (Int) - The number of column segments. | 100 |
Instances
Notes
Methods
- Return the body and the deformable surface.
- getBody()
- If the selected DeformableSurface is using markers, return the body used by the first marker. If it is using bodies and points, return the first body.
Surface Graphic
Class SurfaceGraphic()
SurfaceGraphic(parent='MODEL', name='SurfaceGraphic_n', label='SurfaceGraphic_n', active=True,
wire_mode='OFF', shade_mode='USE_MATERIAL', is_material_inside=True, refinement_level=3, advjoint=None,
surf_sel=None, num_u_segs=100, num_v_segs=100)
Surface graphic.
Keyword Arguments
name | String | The variable name. | Point_n, for next available integer n. |
label | String | The descriptive label. | Point_n, for next available integer n. |
advjoint | DeformableSurface | The associated advanced joint. | None |
surf_sel | Enum | Surface number when type of advanced joint is SurfaceToSurfaceJoint. One of SURF1 or SURF2 | |
num_u_segs | Int | The number of row segments. | 100 |
num_v_segs | Int | The number of column segments. | 100 |
Instances
Notes
Methods
- Return the body and the advanced joint.
- getBody()
- Get the body that this graphic is for from the selected advanced joints b1.
Examples
Create and modify attributes of a Surface graphic.
>>> s1 = mview.Surface()
>>> #For SolverMode = ADAMS
>>> h3dpath = r"C:\Users\user\Desktop\surfacefile.h3d"
>>> parasolid = r"C:\Users\user\Desktop\surfacefile.x_t"
>>> #If file is an H3D graphic file
>>> s1.graphic_file = h3dpath
>>> #Set multiple values at once (if file is a parasolid file)
>>> s1.setValues(parasolid_file = parasolid, use_parasolid_comp = True)
>>> s1.parasolid_comp = 'surf1'
>>> s1.vopen_closed
'VOPEN'
>>> s1.vopen_closed = 'VCLOSED'
>>> s1.uopen_closed = 'UOPEN'
Graphic System
Class GraphicSystem()
class GraphicSystem(**kwds)
A GraphicSystem is a type of System which can only contain graphic entities or other graphic systems.
name | String | The variable name. | GraphicSystem_n, for next available integer n. |
label | String | The descriptive label. | GraphicSystem_n, for next available integer n. |
Variables
linked_definitions | Reference | List of system handles which have share the same definition name. | |
is_linked | Bool | Indicates whether definition name of this system is used by any other system in the model. | |
atts | Dict | Dictionary of all attachment's local variable names and their handles. | |
dss | Dict | Dictionary of all dataset's variable names and their handles which are inside this system. | |
datas | Dict | Dictionary of all option's variable names and their handles which are on this system. |
Methods
- getAssociatedGraphics()
- Get any graphics that are associated with this object.
Examples
Create and modify attributes of a Graphic system.
>>> gs = mview.GraphicSystem(name='gsys')
>>> #Create a body for the graphics
>>> b1 = mview.Body(name = 'b1',inertia_props_from_graphic = True)
>>> #Add attachment to the graphic system
>>> gs.addAttachment(name = 'att_body',type = 'Body',value = b1)
>>> #Create a child graphic entity for the graphic system
>>> bx1 = mview.Box(parent = gs,name = 'bx1',itype = 'CENTER')
>>> bx1.align_meth1 = 'VECTOR'
>>> bx1.align_vec1 = mview.getModel().V_Global_Z
>>> #Set multiple values at once (setting attachment as the reference here)
>>> bx1.setValues(body = "att_body",origin = "P_Global_Origin")
>>> #Get child object handles of GraphicSystem in a lists
>>> gs.getChildren()
[<hw.mview.mbd.System.Attachment object at 0x000002341F8EE5F8>, <hw.mview.mbd.Graphic.Box object at 0x000002341F8C2668>]
