SpringDamper
SpringDamper
Class SpringDamper()
SpringDamper(parent='MODEL', name='SpringDamper_n', label='SpringDamper_n',
active=True, type='CoilSpring', b1=None, b2=None, p1=None, p2=None, f=0, len=0, t=0,
ang=0, origin=None, align_meth1='Point', align_pt1=None, align_vec1=None)
Create a spring damper of type coil spring or torsion spring.
Keyword Arguments
Argument | Data Type | Description | Default |
name | String | The variable name. | SpringDamper_n, for next available integer n. |
label | String | The descriptive label. | SpringDamper_n, for next available integer n. |
parent | Object | The parent. | MODEL |
active | Boolean | Used to activate or deactivate this entity. | True |
type | Enum | They type. One of CoilSpring or TorsionSpring. | CoilSpring |
b1 | Body | The first body to which the spring is attached. | None |
b2 | Body | The second body to which the spring is attached. | None |
p1 | Point | The point at which the coil spring is attached to b1. | None |
p2 | Point | The point at which the coil spring is attached to b2. | None |
f | Double | The load on the coil spring at a particular length. | 0 |
len | Double | The length of the coil spring when it has a particular load. | 0 |
t | Double | The load on the torsion spring when it has a particular angle. | 0 |
ang | Double | The angle of the torsion when the spring has a particular load. | 0 |
origin | Point | The location for torsion spring. | None |
align_meth1 | MultiRef | Alignment method for torsion spring. One of Point or Vector. | Point |
align_pt1 | Point | Reference point for alignment when align_meth1 is Point. | None |
align_vec1 | Vector | Reference vector for alignment when align_meth1 is Vector. | None |
Instances
Instance | Type | Description | |
k | Nonlinear | The stiffness coefficient of the spring. | |
c | Nonlinear | The damping coefficient of the spring. | |
kt | Nonlinear | The stiffness coefficient of the torsion spring. | |
ct | Nonlinear | The damping coefficient of the torsion spring. | |
i | Marker | The marker on b1. | |
j | Marker | The marker on b2. |
Readonly Properties
dist_x | Double | Distance between p1 and p2 in x. |
dist_y | Double | Distance between p1 and p2 in y. |
dist_z | Double | Distance between p1 and p2 in z. |
dist_mag | Double | Magnitude of distance between p1 and p2 in x. |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
3. Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
4. Readonly Properties cannot be modified.
Methods
- getAssociatedGraphics()
Get all the graphics that are associated with this object.
Returns:
List of all graphic associated with this body.
Return type:
(list)
Spring Damper Pair
Class SpringDamperPair
SpringDamperPair(parent='MODEL', name='SpringDamperPair_n',
label='SpringDamperPair_n', active=True, sym='NONE')
SpringDamper pair containing left and right instances of singles.
Keyword Arguments
name | String | The variable name. | SpringDamperPair_n, for next available integer n. |
label | String | The descriptive label. | SpringDamperPair_n, for next available integer n. |
active | Bool | Defines if entity is activated when True or deactivated when False. | True |
sym | Enum | The symmetry of pair entity. Takes values 'LEFT' for left entity as master, 'RIGHT' for right entity as master or 'NONE' when it is not symmetric. | ‘NONE' |
Instances
l | Point | The left SpringDamper. |
r | Point | The right SpringDamper. |
Notes
Examples
Create a spring damper and modify its attribute values.
>>> # Import mview module
>>> from hw import mview
>>> # Create body and point for SpringDamper
>>> b1 = mview.Body(name = 'b1', label = 'top body',usecm = True)
>>> p1 = mview.Point(name = 'startpoint', x = 60)
>>> b1.cg = p1
>>> # Create a coil spring SpringDamper for the graphic
>>> spdp = mview.SpringDamper(name = 'spdp')
>>> # Set multiple values at once
>>> spdp.setValues(b1 = b1, b2 = 'B_Ground',p1 = p1, p2 = 'P_Global_Origin')
>>> # Get value of attribute
>>> spdp.k.lin
0.0
>>> # Set stiffness as an expression
>>> spdp.k.type = 'EXPR'
>>> spdp.k.expr = "`STEP5(TIME,0,0,5,25)`"
>>> # Set damping coefficient as a curve
>>> spdp.c.type = 'CRV'
>>> c1 = mview.Curve(x_type = 'VALUE',y_type = 'VALUE',x_value = [0,1,2],y_value = [10,20,5])
>>> spdp.c.crv = c1
>>> # Set interpolation type and independant variable
>>> spdp.c.int_type = 'CUBIC'
>>> spdp.c.indep_var = '`TIME`'
>>> # Change the type to torsion spring
>>> spdp.type = 'TorsionSpring'
>>> spdp.setValues(origin = p1,align_meth1 = 'VECTOR',align_vec1 = 'V_Global_Z'
>>> spdp.kty.lin = 25
>>> # Follow similar procedure for SpringDamperPair
>>> spdp = mview.SpringDamperPair(name = 'spdp2',sym = 'RIGHT')
>>> spdp.r.k.lin = 25
>>> spdp.l.k.lin
25.0
