PolyBeam
Class PolyBeam()
PolyBeam(parent='MODEL', name='PolyBeam_n', label='PolyBeam_n', active=True,
points=[None, None], ID=0, OD=0, density=0, E=0, G=0, as_=0, cratio=0)
A polybeam is modeled as a number of beam segments connecting intermediate bodies created internally by MotionView.
Keyword Arguments
Argument Data Type Description Default
name String The variable name. PolyBeam_n, for next available integer n.
label String The descriptive label. PolyBeam_n, for next available integer n.
parent Object The parent. MODEL
active Boolean Used to activate or deactivate this entity. True
points list The points that describe the polybeam. [None, None]
ID Double The inner diameter of the cross section. 0
OD Double The outer diameter of the cross section. 0
density Double The density. 0
E Double The Young's modulus. 0
G Double The shear modulus. 0
as Double The shear correction factor. 0
cratio Double Input needed. 0
Instances
Instance Type Description
color_mat ColorMat The color_mat instance to modify color properties.
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
3. Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
