Loading [MathJax]/jax/output/CommonHTML/jax.js
SolverString
Class SolverString()
SolverString(parent='MODEL', name='SolverString_n', label='SolverString_n', active=True, value=''))
Creates a string within the solver input file.
Keyword Arguments
Argument Data Type Description Default
name String The variable name. SolverString_n, for next available integer n.
label String The descriptive label. SolverString_n, for next available integer n.
parent Object The parent. MODEL
active Boolean Used to activate or deactivate this entity. True
value Double The value of solver string. Defaults to ''. * user (Bool) : Use user defined properties, if true. False
usr_sub Function The expression passed to the user dll. When using solver expressions, Templex syntax (within ) is used and all variables are enclosed in braces {} and the rest is treated as literal. 'USER()'
local_funcname String The function/subroutine name. 'MOTSUB'
use_local_dll Bool Uses a local function instead of default if True. False
local_dll File The path of the local dll which has the local_funcname. ''
local_func_type Enum The type of the user subroutine. One of DLL, PYTHON or MATLAB. 'DLL'
Examples
   >>> # Import the mview module
   >>> from hw import mview
   >>> # Create a SolverString
   >>> solstr = mview.SolverString(name = 'solstr', label = 'Solver mode')
   >>> solstr.value = 'ABAQUS'
   >>> # Cross check the SolverString value
   >>> solstr.value
   'ABAQUS'
   >>> # Change the solver mode using SolverString
   >>> mview.getModel().SolverMode.value = solstr.value
   >>> # Check the solver mode now
   'ABAQUS'
