Headers and Footers View
The Headers/Footers view, , displays only the header and footers in the session,
grouped within their respective page and plot folders. Click on a header or footer
to display its properties in the Entity Editor.
![](../../images/hypergraph/plot_browser_header_footer_view_hgx.png)
When a header or footer is selected, the following fields are displayed in the Entity Editor:
Standard
- Text
- The header or footer label.
- In the Text field, the curve name is defined by a Templex expression instead of a fixed string. The Templex expression is visible in editable fields only. In non-editable fields, the evaluated expression is displayed. In most cases, the evaluated expression should match the text that was hard-coded in previous versions. Please see Dynamic Curve Names for more important information on this topic.
- Visibility
- Turns on/off the header/footer display in the modeling window.
- Type
- Displays Header or Footer, depending what is selected from the upper portion of the browser.
Display
- Font Settings
- Set font attributes for the header or footer.
- Alignment
- Position the header or footer on the left, center, or right side of the modeling window.
- Color
- Select a header or footer text color from the color palette
On the Header tab of the Headers and Footers panel, the curve name is defined by a Templex expression instead of a fixed string. The Templex expression is visible in editable fields only. In non-editable fields, the evaluated expression is displayed. In most cases, the evaluated expression should match the text that was hard-coded in previous versions. Please see Dynamic Curve Namesfor more important information on this topic.
