poIQueryIgnoreElemTypeRule SetNumberAdjacent
Sets the number of adjacent elements to ignore.
rule_handle SetNumberAdjacent value
HyperView Tcl Modify
This command is used to set the number of adjacent elements to ignore from the advanced query.
value
Accepts an integer value.
To set the number of adjacent elements to ignore from the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule ignoreelemtype]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetElementTypeList "rigidlink Quad4"
rule_handle SetNumberAdjacent 1
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations “current” “current”
advancedQuery_handle SetQueryRule "[rule_handle GetID]"
advancedQuery_handle SetQuery “entity.id entity.value”
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_Error, if the value passed is less than 0.
