poIQueryIgnoreElemTypeRule SetElementTypeList
Sets the element type list to elements from the advanced query.
rule_handle SetElementTypeList typelist
HyperView Tcl Modify
This command is used to set the element configs to ignore elements while querying the result.
typelist
Accepts element config types.
To set the element type list to the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule ignoreelemtype]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetElementTypeList "rigidlink Quad4"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations “current” “current”
advancedQuery_handle SetQueryRule "[rule_handle GetID]"
advancedQuery_handle SetQuery “entity.id entity.value”
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_Error, if an invalid config type is passed to the type list.
