poIPost GetResultOverlayModelList
Gets the list of model IDs which are participating in Result overlay (multi-model plot).
poIPost_handle GetResultOverlayModelList
HyperView Tcl Query
This command returns the model list which are participating in result overlay.
To get the model list which are participating in result overlay or multi-model plot:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set model_file1 “” # set the path
set model_file2 “” # set the path
set mid1 [client_handle AddModel $model_file1]
set mid2 [client_handle AddModel $model_file2]
client_handle AddModelToResultOverlay $mid1
client_handle AddModelToResultOverlay $mid2
client_handle RemoveModelFromResultOverlay $mid1
set list [client_handle GetResultOverlayModelList]
hwi CloseStack
Returns an error if the post handle is not valid.
