poIPost GetBestViewTransparency
Gets the transparency level applied for all best views.
poIPost_handle GetBestViewTransparency
HyperView Tcl Query
This command returns the transparency level for all best views in the session.
Note: 0.9 is the highest level of transparency and 0.1 is the lowest level.
To get the transparency level for all best views:
post_handle GetBestViewTransparency
Returns the transparency level value between 0.1 and 0.9.
