poILayerFilter SetLabel
Sets the label for the layer filter.
poILayerFilter_handle SetLabel set_label
HyperView Tcl Modify
This command sets the label for the layer filter.
set_label
The label for the layer filter.
To create the layer filter, get the handle for the filter, and then set the label for the filter to "45 deg plies":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 “Composite Stress” 2
result_handle GetLayerFilterHandle filter_handle 1
filter_handle SetLabel “45 deg plies”
hwi CloseStack
Error
Returns an error if the layer filter controller handle is invalid and if a filter with same name is available.
