poILayerFilter SetDescription
Sets the description for the layer filter.
poILayerFilter_handle SetDescription description
HyperView Tcl Modify
This command sets the description for the layer filter.
description
The description for the layer filter.
To create the layer filter, get the handle for the filter, and then set the description for the layer filter:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 “Composite Stress” 2
result_handle GetLayerFilterHandle filter_handle 1
filter_handle SetDescription “Plies with 45 deg ply angle”
hwi CloseStack
Returns an error if the layer filter controller handle is invalid.
