SetNoteShowSpotID
Sets whether or not the spot ID is shown in the note text.
bestview_handle SetNoteShowSpotID active
HyperView Tcl Modify
This command sets whether or not the spot ID is shown in the note text.
Note: To change the format and the contents of the best view note, you should create a note inside the current HyperView window and label the note as “master” and then activate a best view. This can also be done using the poINote Class APIs under poIPost.
When a master note is present, the format and content of the master note will be followed for all best view evaluations.
active
True or false.
To set the spot ID to show in the note text:
bestview_handle SetNoteShowSpotID true
Returns success (0) and is set only if the string passed is "true".
