Sets the note offset distance from the entity center.
bestview_handle
SetNoteDistance
distance
HyperView Tcl Modify
This command sets the note offset distance from the entity center. This distance is not
followed during the global, globalregions, globalcomponents, or globalspheres view modes
where multiple notes are present and there is a chance of overlap.
Note: To change the format
and the contents of the best view note, you should create a note inside the current
HyperView window and label the note as “master” and then
activate a best view. This can also be done using the poINote Class APIs under
poIPost.
When a master note is present, the format and content of the master note will
be followed for all best view evaluations.
- distance
- The offset in screen percentage (0.1 would be 10% of the screen height and
width).
To set the note offset distance to
20%:
bestview_handle SetNoteDistance 0.2
Returns success (0) or an error code.
