poIAdvancedQuery SetNumericFormat
Sets the numeric format for output values.
advancedQuery_handle SetNumericFormat format
HyperView Tcl Modify
This command is used to set the numeric format to the advanced query to get the formatted output values.
format
Accepted formats include: fixed, scientific, and engineering.
To set the numeric format to the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle SetNumericFormat "fixed"
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_Error, if invalid strings are passed to the argument name.
