poIAdvancedQuery GetNumericFormat
Gets the numeric format from the advanced query.
advancedQuery_handle GetNumericFormat
HyperView Tcl Query
This command is used to get the numeric format from the advanced query.
To get the numeric format from the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle SetNumericFormat "fixed"
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with the advanced query handle does not exist anymore.
