HMMOD_nodesetresult()
Assigns a nodal result to a node specified by the node pointer, layer and index.
void HMMOD_nodesetresult(void * nodeptr, int layer, int index, float value);
HyperMesh hmmodlib Function
nodeptr
The pointer to the node.
layer
The layer where the nodal result should be stored.
index
The index of nodal results.
value
The value to be assigned to the nodal result at the specified node.
None.
