HMMOD_elementidsetcentroidalresult()
Assigns a centroidal result for an element specified by ID, layer, and index.
void HMMOD_elementidsetcentroidalresult(HM_entityidtype id, int layer, int index, float value);
HyperMesh hmmodlib Function
id
The ID of the element.
layer
The layer where the centroidal result should be stored.
index
The index into the array of centroidal results.
value
The value to be assigned to the centroidal result at the specified ID.
None.
