HMMOD_nodeidsetdisplacement()
Assigns displacement values to a node specified by ID.
void HMMOD_nodeidsetdisplacement(HM_entityidtype id, float x, float y, float z);
HyperMesh hmmodlib Function
id
The ID of the node.
x
The displacement value to be assigned to the x coordinate.
y
The displacement value to be assigned to the y coordinate.
z
The displacement value to be assigned to the z coordinate.
None.
