HMMOD_elementsetcentroidalresult()
Assigns a value to the result at the centroid of an element specified by element pointer, layer, and index.
void HMMOD_elementsetcentroidalresult(void * elementptr, int layer, int index, float value);
HyperMesh hmmodlib Function
elementptr
The pointer to the element.
layer
The layer where the centroidal result is to be stored.
index
The index to the array of centroidal results.
value
The value to be assigned to the centroidal result of the specified element.
None.
