HMMOD_elementidsetintegrationpointresult()
Assigns a value to the result at an integration point of an element specified by ID, layer, integration point, and index.
void HMMOD_elementidsetintegrationpointresult(HM_entityidtype id, int layer, int integrationpoint, int index, float value);
HyperMesh hmmodlib Function
id
The ID of the element.
layer
The layer where the integration point result should be stored.
integrationpoint
The integration point where the result should be stored.
index
The index into the array of integration point results.
value
The value to be assigned to the result at the integration point.
None.
