HM_dynamicblockadd()
Adds an item to a dynamic block.
void * HM_dynamicblockadd(void * blockptr);
HyperMesh hmlib Function
blockptr
A pointer to a dynamic block. This pointer must be allocated with HM_dynamicblockallocate().
A pointer to an item allocated in the dynamic block. The amount of memory allocated for the item is specified in the call HM_dynamicblockallocate().
If unsuccessful, the function calls HM_terminate() with the appropriate message, and program execution is terminated.
None.
