Solver Conversion
Enhancements
- LS-DYNA to Radioss Conversion
- *MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE/ MAT_240 converted to /MAT/LAW83, /FAIL/SNCONNECT and property /PROP/CONNECT
- *MAT_COMPOSITE_FAILURE_SHELL_MODEL / MAT_059 converted to /MAT/LAW25 (CRASURV) and the property /PROP/SH_SANDW
- *MAT_POWER_LAW_PLASTICITY_OPTION / MAT_018 converted to /MAT/PLAS_TAB(LAW36)
- *MAT_OGDEN_RUBBER / LAW_077_O converted to /MAT/LAW42 (Ogden)
- Abaqus to OptiStruct
- *connector section SLOT, ALIGN to OptiStruct JOINTG TRANSLAT
- *connector section JOIN to OptiStruct JOINTG RPIN
- *connector section JOIN ALIGN to OptiStruct JOINTG RBEAM
- *HYPERELASTIC MATERIAL converted to MATHE (uniaxial,biaxial,shear and volumetric)
- *CONTACT PAIR, Finite converted to CONTACT, CONSLI
- *DSLOAD converted to PLOADSF
- *SPECIFIC HEAT converted to MATT4
- *EXPANSION,ZERO is converted to MAT1,TREF
- Abaqus to Radioss
- /R3D4 converted to /PROP/SHELL with /RBODY
- *BEAM GENERAL SECTION converted to P3_BEAM
- *OUTPUT, FIELD,RF converted to /ANIM/VECT/FREAC
- *HYPERELASTIC MATERIAL converted to /MAT/LAW92
- *ORIENTATION converted to /SKEW/FIX
- LS-DYNA to OptiStruct
- *CONSTRAINED NODAL RIGID BODY is converted to RBODY/RBADD
- OptiStruct to Abaqus
- Nodal offsets converted from OptiStruct to Abaqus
