Model Verification
Enhancements
- Support of SolidWorks data is added in Comparison and Verification function.
- Cumulative match% calculation logic is improved for CAD vs FE comparison. Cumulative match% =Total target matched area / Total source matched area.
- Fe-attach function supports component name while finding attached parts in addition to shared node logic.
- Method of calculating Thickness from solid CAD is populated on the Browser and Excel report.
- Report generation time can be reduced by editing facet size under general/discretization, 1-6 level exist, Level 1 reduces time.
- Skip-thumbnailassemblyimage parameter is added to skip assembly images in
comparison thumbnail PPT report to improve performance, default=OFF.Figure 1.
- Batch mode is added for Quick Comparison and Spot Comparison function.
- HM file containing Geometric data is supported in Mixed Import option.
- Performance improved for Connection check / Free Hole, Hole Mismatch functions.
- Intersected part’s coordinates and depth values are exported in csv file by
default. File
name=ProjectName-Model_Intersection_Depth.csv under
report path.Figure 2.
General
- Reset button is added on configuration file to restore original setting.
- Auto migration of configuration file is done if old configuration is used preserving user parameters.
- Comparison and Import log messages are improved for debugging the function.
- Tool tips are added for all parameters.
- Existing Part Sets will be deleted on each execution of Part / Match function.
- Part Set name considers names from Part Name and Part Number, in addition
filtered data and unprocessed data are shown in sets.Figure 3.
Resolved Issues
- Spot Comparison, Fixed an issue on executing checks on MAT 100(Hexa) weld type.
- Spot Comparison, Fixed an issue on considers point vs. point data comparison.
- Comparison/Verification, Fixed an issue on Batch mode incorrect progress% message under progress.log.
- Comparison, Fixed an issue in Auto comparison showing false unmatched entities.
