Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Export an input deck, for the appropriate solver, in order to simulate the deformation of the seat under the dummy.
The simulation result files can be imported to update the initial FE model and remove the intersections and penetrations
between the dummy and the seat.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal
input, therefore reducing the full process lead time.
Seat Mechanism
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Seatbelt System
Use the Seatbelt Browser to create a complete seatbelt system.
Pre-Simulation (Seat Deformer) Setup
Export an input deck, for the appropriate solver, in order to simulate the deformation of the seat under the dummy. The simulation result files can be imported to update the initial FE model and remove the intersections and penetrations between the dummy and the seat.
Pedestrian Impact
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time.
