Topology Panel
Use the Topology panel to define design domains for topology optimization.
Note: Only available in the OptiStruct solver interface.
Create Subpanel
Option Action
desvar Specify a name for the design variable.
props Select one or more properties of the selected type.
type Select a property type.
base thickness Choose to use the default base thickness of 0.0 or specify a non-zero value for the base thickness.
A component's total thickness is the same as the thickness given in its PSHELL card.
Note: Available when type is set to PSHELL.
Update Subpanel
Option Action
Parameters Subpanel
Option Action
minmemb off / mindim = Specify a value for the minimum member size control, or toggle the switch to off.
maxmemb off / maxmemb Specify a value for the maximum member size control, or toggle the switch to off.
stress constraint Specify a value for the stress constraint, or toggle the switch to none.
fatigue constraint Choose none, damage < or life >.
mesh type Specify a minimum dimensions value smaller than the recommended size of 3 times average element length by enabling the mesh type checkbox and select aligned.
This defines your mesh as being rectilinear and generally aligned in a single direction.
Draw Subpanel
Option Action
draw type Select none, single or split.
Extrusion Subpanel
Option Action
extrusion type Select none, no twist or twist.
primary path Specify the direction of the extrusion.
secondary path Specify how the extrusion is twisted.
Pattern Grouping Subpanel
Option Action
pattern type Select a pattern type.
Pattern Repetition Subpanel
Option Action
main / secondary / none Select whether you are establishing a main coordinate system, a secondary design variable, or neither.
system /coordinates Choose to manually enter the values for the coordinate system, or to graphically select the system.
global system / local system Select a reference coordinate system.
anchor Select the anchor node.
Command Buttons
Button Action
create Create the design variable.
reject Revert the most recent changes.
review Review the load in the graphic area.
update Update the load with the most recent changes.
return Exit the panel.
