Plot Titles Panel
Use the Plot Titles panel to edit the title information contained in a plot.
Use the Plot Titles panel to edit the titles, subtitles and labels that appear at the top of the plot. You may also change the color and the size of the font used in the plot titles. The update function allows you to change the title attributes of several plots at once.
Panel Options
Option Action
plot = Click plot =, then select the plot to which you want to add or change the plot titles.
plots Select plots.
title = Displays the title of the selected plot. This field cannot be modified.
subtitle = Displays the subtitle of the selected plot. This field cannot be modified.
label = Displays the label of the selected plot. This field cannot be modified.
colors: title / subtitle / label Select a color to assign to the corresponding text.
fonts: title / subtitle / label Select a font to assign to the corresponding text.
Command Buttons
Button Action
update When you select one or more plots and click this button, the plot attributes that can be updated populate the input fields. You can then make changes and click update again to apply them.
return Exit the panel.
