Sort Entities
Sort the entities within a folder.
View new features for HyperLife Weld Certification 2021.
Discover the software compatible with HyperLife Weld Certification.
Discover the files required to work with HyperLife Weld Certification.
Explore the HyperLife Weld Certification user interface.
The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperLife Weld Certification. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
Browsers supply a great deal of view-related functionality in HyperLife Weld Certification by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Learn the basics of working with browsers.
Expand and collapse folders to better view model hierarchy.
The search bar can be used to find and filter entities in a browser.
The Entity Editor enables you to quickly edit entities in a model and correctly setup solver information.
In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
The Model Browser displays and organizes all of the entities in your model in a tree structure and enables access to objects that are not currently shown in the modeling window.
The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
The modeling window is where your model is displayed.
The status bar displays information pertaining to the currently loaded model.
Context menus are floating menus that are accessed by right-clicking on elements in the user interface. They provides immediate access to a short list of commands that are contextually relevant to the selection.
The Tcl Console enables you to enter and execute Tcl/Tk commands instead of using the user interface.
The Message Log lists the actions performed in the current session. The dialog also provides you with information about your file (warnings, errors, and so on).
Command files can be used to create new command scripts that perform automation, or to recover previously performed steps.
Certain parts of the user interface, such as browsers, toolbars, and panels, can be undocked and repositioned as needed.
View controls enable you to control the view and display of your model in the modeling window.
Select and deselect entities to modify with other HyperLife Weld Certification tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to draw, length, angle, and radius measurements in the modeling window.
Undo and redo actions performed in HyperLife Weld Certification.
Default keyboard shortcuts and mouse controls.
Discover HyperLife Weld Certification functionality with interactive tutorials.
Learn the features and benefits of HyperLife Weld Certification.
Set up the model for weld evaluation.
Learn details about the core modules used in HL-WC calculations along with the parameters that are assigned based on the standards.
Learn how to manipulate entities in HyperLife Weld Certification.
ON THIS PAGE
Repeated clicks toggle between ascending and descending order.
ON THIS PAGE
