User Interface
Explore the HyperLife Weld Certification user interface.
The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperLife Weld Certification. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools. Browsers supply a great deal of view-related functionality in HyperLife Weld Certification by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts. Use entity selectors to specify which type of entity you are able to select. The modeling window is where your model is displayed. View controls enable you to control the view and display of your model in the modeling window. The status bar displays information pertaining to the currently loaded model.
  1. Menu Bar
    The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
  2. Ribbons
  3. Browsers
  4. Entity Selectors
  5. Modeling Window
  6. View Controls
  7. Status Bar
