Input Requirements
Discover the files required to work with HyperLife Weld Certification.
Table 1. Files Required
File Description Remarks
FE Model File The FE Model File The current version of HL-WC supports model and results from the following solvers:
  • OptiStruct
  • Nastran
FE Results File The FE Results File The FE Results must contain model data and stress results.
Weld Property File (Optional) This file contains the data of all the classification parameters with respect to each weld line. This file may not be available when working with a new model in HL-WC.
