Double Cable Shield
This option defines a cable shield with two layers.
Figure 1. The SH - Cable shield dialog, set to 2 layers.
Parameters:
Shield label
The name of the shield.
Number of layers
The total number of layers.
Material label
The label of the dielectric (as defined in the DI card) to be used as the coating for the cable.
Thickness of layer for coating
Define the thickness of the dielectric coating.
Shield definition label (Zt + Zs)
The shield layer (SD card) that is to be used for the impedance part of layer 1.
Shield definition label (Yt)
The shield layer (SD card) that is to be used for the admittance part of layer 1.
Gap between layer 1 and 2 (m)
Air (free space) gap between layer 1 and layer 2 in meters.
The shield layer (SD card) to be used for the impedance part of layer 2.
The shield layer (SD card) to be used for the admittance part of layer 2.
