Threshold Analysis
Analyze prediction results with the Threshold Tool using an arbitrarily user defined threshold value.
The threshold tool is applied to prediction results computed for horizontal planes (area predictions) using an arbitrarily user defined threshold value. The Threshold Tool can be started by selecting
from the Analysis menu or by pressing the corresponding button on the Analysis toolbar. The result to be considered has to be loaded using the File Browser prior to starting the tool. After starting the Threshold Tool a dialog opens, where the user defined threshold can be specified.![](../../../../../images/winprop/user_guide/connectivity_manager/basics/dialog_field_strength.jpeg)
Figure 1. The Field Strength dialog.
The threshold plot will be displayed after closing the dialog by pressing OK.
![](../../../../../images/winprop/user_guide/connectivity_manager/basics/threshold_tool.jpeg)
Figure 2. Example of the threshold tool.
The Threshold Tool can be closed by selecting
from the Analysis menu or by pressing the corresponding button on the Analysis toolbar again. The original result will be visualized then.
