Components
CoMan offers the possibility to define standard components, which can be used as templates in different projects.
Component Catalog
The Component Catalog can be opened using the menu . By default, there are three different predefined node types as well as a wireless system. These default entries can be modified, copied or deleted using the corresponding buttons at the bottom of the dialog. Further nodes and systems can be added to the component list by selecting the corresponding Add button. After modifications have been done, the catalog should be stored by pressing the Save button in the upper part of the dialog. Already existing Component Catalogs can be loaded using the Load button.
