Supported File Formats
View a list of supported file formats for import and export.
By default, models created in Inspire Studio are saved in the native format with the file extension .istudio.
The installation program allows you to select import/export plug-ins to be installed.
Import
- Inspire Studio models (.iStudio, .evo, .st, .stm)
- Thea Studio (.thea)
- Altair Inspire (.stmod)
- VRML (.vrml, .wrl)
- Point cloud (.cld, .txt)
- IGES (.iges, .igs)
- STEP (.stp, .step)
- Parasolid (.x_t, .xmt_txt, .x_b, xmt_bin)
- ACIS (.sat)
- CATIA V4 (.model, .dlv, .exp, .session)
- CATIA V5 (.CATPart, .CATProduct, .cgr)
- CATIA V6 (.3Dxml)
- SolidWorks (.sldprt, .sldasm)
- Pro/ENGINEER and Creo (.prt, .asm, .neu)
- Unigraphics/NX (.prt)
- Inventor (.ipt, .aim)
- JT (.jt)
- I-DEAS (.arc, .unv)
- VDA (.vda)
- H3D (.h3d)
- STL (.stl)
- 3DStudio (.3ds)
- OBJ (.obj)
- Rhino (.3dm)
- Scalable vector graphics (.svg)
- AutoCAD Drawing (.dwg, .dxf)
Export
- Inspire Studio models and bundles (.iStudio, .evo)
- AltairInspire (.stmod)
- VRML (.wrl)
- IGES (.igs)
- STEP (.stp)
- Parasolid (.x_t)
- Parasolid binary (.x_b)
- ACIS (.sat)
- VDA (.vda)
- STL (.stl)
- 3DStudio (.3ds)
- OBJ (.obj)
- Rhino (.3dm)
- AutoCAD Drawing Exchange (.dxf)
- AutoCAD Drawing (.dwg)
- PDF (.pdf)
What type of data is imported/exported?
| File Format | Import | Export |
| 3D STUDIO (.3ds) |
| ACIS (.sat) |
Where available, assembly structure is imported as hierarchical groups. |
| ARCH BILL (.txt) | Architecture objects Creates a text file listing information (area, volume, quantity, etc.) about the objects created by the Architecture modeling tools. |
| AUTOCAD (.dwg) |
| AUTOCAD ASCII (.dxf) |
| CATIA |
| I-DEAS (.arc, .unv) |
| IGES - Initial Graphics Exchange Specification (.igs, .iges) | All the main curve/surface/solid IGES entity types are supported. |
| INVENTOR (.ipt, .iam) |
| JT (.jt) |
| OBJ (.obj) |
| PARASOLID (.x_t, .x_b) |
| PDF (.pdf) |
| POINT CLOUD (.cld, .txt) | Point clouds stored as X, Y, and Z coordinates in the file. | |
| Pro/ENGINEER and CREO (.prt, .asm, .neu) |
| RHINO (.3dm) |
Import (v.1 to v.5)
| SOLIDWORKS (.sldprt, .sldasm) |
| STEP - Standard for the Exchange of Product Model Data (.stp, .step) |
| STL - Standard Tessellation Language (.stl) | Objects ASCII and binary format are supported. |
| UNIGRAPHICS/NX (.prt) |
| VDAFS - Verband der Automobilindustrie - Flächenschnittstelle (.vda) |
