Reference Geometry
Create and modify reference planes, axes, or points.
The Reference tools allow you to create planes, axes, and points that you can use as references to help build your model. If you roll back your model to previous stage of its construction history and change the shape or dimensions of your original geometry, the associated reference planes, axes, and points will adapt to the geometry’s new shape. There is no need to re-create the reference.
