Offset
Offset parts or surfaces, or thicken parts to convert them to thin solids.
- In the context of the Offset tool, the
arrow is an indicator only, not a
drag handle. - Negative values in the microdialog field are not supported.
Offset Solid Parts
Select one or more parts to offset.
Offset Surfaces on Solids
Select one or more surfaces to offset.
Thicken Surfaces on Solid Parts
Thicken all of the surfaces on a solid part to convert them to thin solids.
