/INISHE/STRS_F/GLOB or /INISH3/STRS_F/GLOB
Block Format Keyword Describes the initialization of stress tensor given in global coordinate system for shell elements.
| /INISHE/STRS_F/GLOB/unit_ID or /INISH3/STRS_F/GLOB/unit_ID | |||||||||
| shell_ID | nb_integr | npg | Thick | ||||||
| Em | Eb | H1 | H2 | H3 | |||||
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| shell_ID | Element
identifier. (Integer) |
| nb_integr | Integration point number
through the thickness. (Integer) |
| npg | Number of surface
quadrature points.
(Integer) |
| Thick | Shell thickness. 6 (Real) |
| Em | Total membrane
energy. (Real) |
| Eb | Total bending
energy. (Real) |
| H1, H2, H3 | Hourglass
force. (Real) |
| , , | Plane stress in the global
frame. (Real) |
| , , | Shear stress in the global
frame. (Real) |
| Bending stress in the
global frame. (Real) |
| Plastic
strain. (Real) |
- The nb_integr should be equal to the nb_integr defined in the shell property definition.
- Only compatible with Ishell =1, 2, 3, 4 or Ish3n =1, 2, 31.
- If nb_integr ≠ 0, repeat the optional continuation lines for each integration point.
- The npg must be set according to the formulation, which is used in the shell property.
- For npg = 0 or 1 and nb_integr > 0, the optional continuation lines have to be repeated for each integration point.
- The value given for thickness (Thick) will be used instead of the thickness given in property or in the shell definition.
