/STATE/STR_FILE
Block Format Keyword Allows to read an initial state (blocks /INISHE, /INISH3, and /INIBRI) by specifying the name of a stress file possibly compressed using GZIP.
| /STATE/STR_FILE | |||||||||
| Izip | |||||||||
| Stress_File_Name | |||||||||
| Izip | Define if the file is
compressed flag.
(Integer, maximum 10 digits) |
| Stress_File_Name | Full name of the stress file, including suffix .str and the possible suffix .gz. |
- A stress file must only contain blocks /INISHE, /INISH3 and /INIBRI.
- For defining an initial state, it is possible to use a state file (.sta), which can directly contain options /INISHE, /INISH3 and /INIBRI or the .sta file can contain this option /STATE/STR_FILE. In this case, options /INISHE, /INISH3 and /INIBRI will belong to the referenced stress file.
- Using a compressed stress file will save disk space.
