_e.out file
An ASCII format results file which can be used for monitoring energy output from nonlinear analysis.
File Creation
This file is created for any implicit nonlinear static or nonlinear transient run when the NLENRG Subcase/Bulk Entry pair is specified.
File Contents
This file provides global and per-entity energy output on-the-fly from an implicit nonlinear run.
File Format
Figure 1. Example
