.flt file
An OptiStruct ASCII format results file containing the summary of aeroelastic flutter analysis.
File Creation
This file is created by default for aeroelastic flutter analysis.
File Contents
Subcase = 1
FLUTTER SUMMARY
CONFIGURATION = AEROSG2D XY-SYMMETRY = ASYMMETRIC XZ-SYMMETRY = SYMMETRIC
POINT = 1 MACH NUMBER = 0.9000 DENSITY RATIO = 1.0000E-01 METHOD = K
KFREQ 1./KFREQ VELOCITY DAMPING FREQUENCY COMPLEX EIGENVALUE
0.0010 1.0000000E+03 UNSTABL-SYSTEM UNSTABL-SYSTEM UNSTABL-SYSTEM 4.3931949E+04 2.0325712E+02
0.0010 1.0000000E+03 STABLE-SYSTEM- STABLE-SYSTEM- STABLE-SYSTEM- 2.0193361E+04 -1.1860746E+02
0.0010 1.0000000E+03 STABLE-SYSTEM- STABLE-SYSTEM- STABLE-SYSTEM- 3.0546665E+05 -7.2971381E+02
*** USER INFORMATION MESSAGE
THE K OR KE METHOD OF FLUTTER ANALYSIS HAS FOUND A ROOT THAT HAS NO PHYSICAL INTERPRETATION.
Subcase = 1
FLUTTER SUMMARY
POINT = 2 MACH NUMBER = 0.9000 DENSITY RATIO = 1.0000E-01 METHOD = K
0.1800 5.5555556E+00 4.1282076E+01 -5.0589764E-02 4.2403886E+00 -1.6998593E+03 -8.5995482E+01
0.1800 5.5555556E+00 1.7230486E+02 -8.9340353E-02 1.7698711E+01 -2.9453872E+04 -2.6314194E+03
0.1800 5.5555556E+00 4.4410222E+02 -5.0649869E-01 4.5617037E+01 -1.5696010E+05 -7.9500083E+04- Result Entity
- Details
- Subcase
- Number of the subcase.
- CONFIGURATION
- Identifies the databases associated with the aerodynamics. Currently, the aerodynamic model is computed from the Bulk Data Entries of the analysis deck and the corresponding database is denoted by AEROSG2D.
- XY-SYMMETRY and XY-SYMMETRY
- Symmetry flags from the AESYMXY and AESYMXZ entries.
- POINT
- Point of the flutter analysis.
- MACH NUMBER
- Mach number specifed in FLFACT entry.
- DENSITY RATIO
- Density ratio specifed in FLFACT entry.
- METHOD
- Method of flutter analysis.
- KFREQ
- Reduced frequency specifed in the FLFACT entry.
- Velocity
- Velocities calculated from the complex eigenvalues.
- Damping
- Damping calculated from the complex eigenvalues.
- Complex eigenvalue
- Calculated complex eigenvalues in the flutter analysis.
- For more details on flutter analysis and output, refer to Dynamic Aeroelastic Analysis in the User Guide.
