.cpr file
The .cpr file is an OptiStruct ASCII format results file.
File Creation
This file is created when CONTPRM,PREPRT,YES is specified in an input file which contains contact.
File Contents
This file contains a summary of initial conditions of contact interfaces. The information is printed as a separate table for each contact interface in the model. Currently, .cpr file output is supported for any model with contact.
File Format
| Type | Name | Content |
| NA | Contact Interface (N2S/S2S) | Lists the ID and name of the Contact Interface |
| NA | Secondary SURF/SET | Lists the ID and name of the Secondary in the Contact Interface |
| NA | Main SURF/SET | Lists the ID and name of the Main in the Contact Interface |
| (I) - Integer | CONTID | Contact interface ID |
| (I) – Integer | SLVGID | Core secondary grid ID of the gap |
| (I) – Integer | NCMSTG | Number of connected main grids of the gap |
| (I) – Integer | NCSLVG | Number of connected secondary grids beside the core secondary grid of the gap (only for S2S contact) |
| (C) - Characters | STATUS | Gap status (OPEN/CLOSED/FROZEN) |
| (R) - Real Number | OPENING | Gap opening (negative value means penetration) |
| (R) – Real Number | RAWGAP | Raw gap opening based on mesh coordinates (adjusted mesh coordinates with N2S ADJUST) |
| (R) – Real Number | PADDING | Gap padding due to GPAD, S2S ADJUST, CLEARANCE, etc. |
| (R) – Real Number | SAREA | Nodal contact area on the core secondary grid (only for S2S contact) |
