Results Output by OptiStruct
The tables in this section summarize the results output for different analysis types. They show the formats available for each result and the I/O Option Entry that controls the output of the result.
- H3D
- Hyper3D format (.h3d file
- HM
- HyperMesh format (.res file)
- OP2
- Nastran Output2 format (.op2 file)
- PCH
- Nastran Punch format (.pch file)
- OPT
- OptiStruct ASCII format (multiple files)
- PAT
- Patran and Alternative-Patran formats (multiple files)
- H3D (MBD)
- Hyper3D format for body results (_mbd.h3d file)
- MRF
- Multibody results file (_mbd.mrf file)
- HDF5
- Hierarchical data format (.h5 file)
Linear Static Analysis and Nonlinear Static Analysis Results
| H3D | HM | OP2 | PCH | OPT | PAT | HDF5 | Controlling I/O Option | |
| Nodal Displacements | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | DISPLACEMENT |
| Element Strain Energy | ✓ | ✓ | ✓ | ✓ | ESE | |||
| Element Stresses4 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | STRESS / ELSTRESS |
| Element Strains 4 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | STRAIN | |
| Ply Stresses | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | CSTRESS | |
| Composite Failure Indices | ✓ | ✓ | ✓ | ✓ | CFAILURE | |||
| Ply Strains | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | CSTRAIN | |
| Element Forces | ✓ | ✓ | ✓ | ✓ | ✓ | ✓# | FORCE / ELFORCE | |
| Grid Point Stresses | ✓ | ✓ | ✓ | ✓ | GPSTRESS / GSTRESS | |||
| SPC Forces | ✓ | ✓ | ✓ | ✓ | ✓# | SPCFORCE | ||
| MPC Forces | ✓ | ✓ | ✓ | ✓ | ✓# | MPCFORCE | ||
| Grid Point Forces | ✓ | ✓ | ✓ | ✓ | ✓# | GPFORCE | ||
| Applied Loads | ✓ | ✓ | ✓ | ✓ | ✓# | OLOAD | ||
| Contact Force and Pressure | ✓ | ✓ | CONTF | |||||
| Total Force | ✓ | TOTALFORCE |
# Available only for Linear Static Analysis
Linear Steady-state Heat Transfer Analysis Results
Linear Transient Heat Transfer Analysis Results
Normal Modes Analysis Results
| Eigenvectors | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | DISPLACEMENT |
| Element Kinetic Energy | ✓ | ✓ | ✓ | ✓ | EKE | |||
| Grid Point Energy | ✓ | GPKE | ||||||
| Grid Point Stress | ✓ | ✓ | GPSTRESS / GSTRESS | |||||
| Element Stresses 4 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | STRESS / ELSTRESS | |
| Element Strains 4 | ✓ | ✓ | STRAIN | |||||
| Element Forces | ✓ | FORCE / ELFORCE | ||||||
| SPC Forces | ✓ | ✓ | ✓ | ✓ | SPCFORCE | |||
| MPC Forces | ✓ | ✓ | ✓ | ✓ | MPCFORCE | |||
| Grid Point Forces | ✓ | ✓ | ✓ | ✓ | GPFORCE | |||
| Nodal Pressures (Fluid) | ✓ | ✓ | ✓ | PRESSURE | ||||
| Ply Stresses | ✓ | CSTRESS | ||||||
| Ply Strains | ✓ | CSTRAIN |
Complex Eigenvalue Analysis Results
| H3D | OP2 | PCH | Controlling I/O Option | |
| Eigenvectors | ✓ | ✓ | ✓ | DISPLACEMENT |
Linear Buckling Analysis Results
| H3D | HM | OP2 | PCH | OPT | HDF5 | Controlling I/O Option | |
| Eigenvectors | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | DISPLACEMENT |
Aeroelastic Divergence Analysis Results
| Result | H3D | OP2 | PCH | Controlling I/O Option |
| Eigenvectors | ✓ | ✓# | ✓# | DISPLACEMENT |
| Element Energy Loss Per Cycle | ✓ | ✓# | EDE | |
| Element Kinetic Energy | ✓ | ✓# | EKE | |
| Element Strain Energy | ✓ | ✓# | ESE |
# In aeroelastic divergence analysis with multiple Mach numbers, only H3D output is available.
Aeroelastic Flutter Analysis
| Displacements | ✓ | ✓ | ✓ | DISPLACEMENT |
| Modal Participation Displacements* | ✓ | ✓# | SDISPLACEMENT |
* SDISPLACEMENT output is available only for K, PK and PKNL methods of aeroelastic flutter analysis.
# PCH output for SDISPLACEMENT is available only in sorting = SORT1.
Frequency Response Analysis Results
| H3D | HM | OP2 | PCH | OPT | XYPUNCH | Controlling I/O Option | |
| Nodal Displacements | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | DISPLACEMENT |
| Modal Participation Displacements | ✓ | ✓ | ✓ | SDISPLACEMENT | |||
| Element Energy Loss Per Cycle | ✓ | ✓ | ✓ | EDE | |||
| Element Kinetic Energy | ✓ | ✓ | ✓ | EKE | |||
| Element Strain Energy | ✓ | ESE | |||||
| Nodal Velocities | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | VELOCITY |
| Modal Participation Velocities | ✓ | ✓ | ✓ | SVELOCITY | |||
| Nodal Accelerations | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ACCELERATION |
| Modal Participation Accelerations | ✓ | ✓ | ✓ | SACCELERATION | |||
| Modal Stresses 3 | ✓ | ✓ | ✓ | STRESS / ELSTRESS | |||
| Modal Strains 3 | ✓ | ✓ | ✓ | STRAIN | |||
| Element Forces | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | FORCE / ELFORCE |
| MPC Forces | ✓ | ✓ | MPCFORCE | ||||
| Grid Point Stresses | ✓ | ✓ | GPSTRESS / GSTRESS | ||||
| Power Flow Field | ✓ | POWERFLOW | |||||
| Ply Strains | ✓ | CSTRAIN | |||||
| Sound Power | ✓ | SPOWER | |||||
| Sound Intensity | ✓ | SINTENS | |||||
| Sound Pressure Level | ✓ | SPL | |||||
| Applied Load Vectors | ✓ | ✓ | ✓ | ✓ | OLOAD | ||
| Composite Failure Indices | ✓ | CFAILURE |
Coupled Frequency Response Analysis of Fluid-structural Models (Acoustic Analysis) Results
| Nodal Displacements | ✓ | ✓ | ✓ | DISPLACEMENT |
| Nodal Velocities | ✓ | ✓ | ✓ | VELOCITY |
| Nodal Accelerations | ✓ | ✓ | ✓ | ACCELERATION |
| Element Stresses 4 | ✓ | ✓ | ✓ | STRESS / ELSTRESS |
| Element Strains 4 | ✓ | ✓ | ✓ | STRAIN |
| Element Forces | ✓ | ✓ | ✓ | FORCE / ELFORCE |
| SPC Forces | ✓ | ✓ | ✓ | SPCFORCE |
| Grid Point Forces | ✓ | ✓ | ✓ | GPFORCE |
| Ply Stress | ✓ | CSTRESS | ||
| Ply Strain | ✓ | CSTRAIN |
Transient Analysis Results
| H3D | HM | OP2 | PCH | OPTI | Controlling I/O Option | |
| Nodal Displacements | ✓ | ✓ | ✓ | ✓ | DISPLACEMENT | |
| Nodal Velocities | ✓ | ✓ | ✓ | ✓ | VELOCITY | |
| Nodal Accelerations | ✓ | ✓ | ✓ | ✓ | ACCELERATION | |
| Element Stresses 4 | ✓ | ✓ | ✓ | ✓ | STRESS / ELSTRESS | |
| Element Strains 4 | ✓ | ✓ | ✓ | ✓ | STRAIN | |
| Element Forces | ✓ | ✓ | ✓ | FORCE / ELFORCE | ||
| Ply Stresses | ✓ | ✓ | ✓ | CSTRESS | ||
| Ply Strains | ✓ | ✓ | ✓ | CSTRAIN | ||
| Composite Failure Indices | ✓ | CFAILURE | ||||
Transient Analysis via Fourier Transformation Results
| Pressure (for Infinite Element Analysis) | ✓ | ✓ | DISPLACEMENT |
Random Response Analysis Results
| OP2 | PCH | H3D | HDF5 | Controlling I/O Option | |
| Displacement (PSD, RMS and RMS (Cumulative)) |
✓ # | ✓ | ✓ | DISPLACEMENT, XYPEAK / XYPLOT / XYPUNCH | |
| Velocity (PSD, RMS and RMS (Cumulative)) |
✓ # | ✓ | ✓ | VELOCITY, XYPEAK / XYPLOT / XYPUNCH | |
| Acceleration (PSD, RMS and RMS (Cumulative)) |
✓ # | ✓ | ✓ | ACCELERATION, XYPEAK / XYPLOT / XYPUNCH | |
| Element Force (PSD and RMS) |
✓ | ✓ | FORCE / ELFORCE, XYPEAK / XYPLOT / XYPUNCH | ||
| Element Stress
(PSD) |
✓ | ✓ | ✓ | STRESS / ELSTRESS, XYPEAK / XYPLOT / XYPUNCH | |
| Element
Stress (RMS) |
✓ | ✓ 1 | ✓ | STRESS / ELSTRESS | |
| Element
Strain (PSD) |
✓ | ✓ | STRAIN, XYPEAK / XYPLOT / XYPUNCH2 | ||
| Element
Strain (RMS) |
✓ | STRAIN | |||
| SPC Force (PSD, RMS and RMS (Cumulative)) |
✓ # | ✓ | ✓ | SPCFORCE | |
| Composite Stress (PSD and RMS) |
✓ | CSTRESS | |||
| Composite Strain (PSD and RMS) |
✓ | CSTRAIN |
# In case of .pch format, only PSD and RMS results are available
Response Spectrum Analysis Results
| Nodal Displacements | ✓ | ✓ | ✓ | DISPLACEMENT | ||
| Nodal Accelerations | ✓ | ✓ | ACCELERATION | |||
| Element Stresses | ✓ | ✓ | ✓ | STRESS / ELSTRESS | ||
| Element Strains | ✓ | ✓ | STRAIN | |||
| Element Forces | ✓ | ✓ | FORCE | |||
| MPC Forces | ✓ | MPCFORCE |
Multibody Dynamics Analysis Results
| H3D | HM | OP2 | H3D (MBD) | MRF | Controlling I/O Option | |
| Nodal Velocities | ✓ | ✓ | ✓ | VELOCITY | ||
| Nodal Accelerations | ✓ | ✓ | ✓ | ACCELERATION | ||
| Body time history | ✓ | |||||
| System time history | ✓ | |||||
| Marker time history | ✓ | REQUEST | ||||
| Element and Joint Forces | ✓ | MBFORCE |
Fatigue Analysis Results
CMS Generation (Flex-Body Generation) Results
| H3D | OP2 | MNF | Controlling I/O Option | |
| Displacements | ✓ | ✓ | DISPLACEMENT | |
| Element Stresses | ✓ | ✓ | STRESS / ELSTRESS | |
| Element Forces
(CBEAM/CBAR/CROD) |
| Grid Point Stress (Solid elements) | ✓* | ✓* | ✓** | GPSTRESS / GSTRESS |
| Grid Point Strain | ✓** | GPSTRAIN | ||
| Multi Point Constraint Force | ✓ | MPCFORCE | ||
| Grid Point Forces | ✓ | GPFORCE |
* Only output for Solid elements.
** Output for Solid and Shell elements.
CMS DMIG Residual Run (FE DMIG) Results
| Element Strain | ✓ | ✓ | ✓ | STRAIN |
| Element Forces (CBEAM/CBAR/CROD) | ✓ | FORCE / ELFORCE | ||
| Grid Point Stress (Solid elements) | ✓* | GPSTRESS / GSTRESS | ||
| Equivalent Radiated Power | ✓ | ERP | ||
* Only output for solid elements.
Explicit Dynamic Analysis Results (ANALYSIS=NLEXPL)
| H3D5 | HM | OP2 | PCH | OPTI | Controlling I/O Option | |
| Nodal Displacements and Rotations | ✓ | DISPLACEMENT | ||||
| Nodal Velocities | ✓ | VELOCITY | ||||
| Nodal Accelerations | ✓ | ACCELERATION | ||||
| Element Stresses | ✓ | STRESS / ELSTRESS | ||||
| Element Strains (including Plastic strain) |
✓ | STRAIN | ||||
| CBUSH Element Forces | ✓ | FORCE / ELFORCE | ||||
| Element Strain energy and Strain energy density | ✓ | ESE |
Explicit Nonlinear Analysis Results (ANALYSIS=EXPDYN)
(Block Format) |
| Nodal Displacements | ✓ | ✓ | DISPLACEMENT | /ANIM/VECT/DISP
/ANIM/VECT/DROT |
| Nodal Velocities | ✓ | ✓ | VELOCITY | /ANIM/VECT/VEL | |
| Nodal Accelerations | ✓ | ✓ | ACCELERATION | /ANIM/VECT/ACC | |
| Element Stresses 4 | ✓ | ✓ | STRESS / ELSTRESS | /ANIM/BRICK/TENS/STRESS /ANIM/SHELL/TENS/STRESS/UPPER /ANIM/SHELL/TENS/STRESS/LOWER /ANIM/BEAM/VONM /ANIM/TRUSS/SIGX |
| Element Strains 4 | ✓ | ✓ | STRAIN | /ANIM/BRICK/TENS/STRAIN
/ANIM/SHELL/TENS/STRAIN/UPPER /ANIM/SHELL/TENS/STRAIN/LOWER |
| Ply Stresses | ✓ | CSTRESS | /ANIM/SHELL/TENS/STRESS/N /ANIM/SHELL/TENS/STRESS/ALL |
| Ply Strains | ✓ | CSTRAIN | /ANIM/SHELL/TENS/STRAIN/ALL | ||
| Composite Failure Indices | ✓ | CFAILURE | N/A | ||
| Element Forces | ✓ | FORCE / ELFORCE | /ANIM/Eltyp/FORC | ||
| Grid Point Stresses | ✓ | GPSTRESS / GSTRESS | /ANIM/GPS1/TENS /ANIM/GPS1/SHELL/UPPER /ANIM/GPS1/SHELL/LOWER |
| SPC Forces | ✓ | ✓ | ✓ | SPCFORCE | /ANIM/VECT/FREAC
/ANIM/VECT/MREAC |
| MPC Forces | ✓ | ✓ | ✓ | MPCFORCE | /ANIM/VECT/FINT |
| Applied Loads | ✓ | ✓ | ✓ | OLOAD | /ANIM/VECT/FEXT |
| Plastic Strain | ✓ | STRAIN (PLASTIC) | /ANIM/ELEM/EPSP /ANIM/SHELL/EPSP/UPPER /ANIM/SHELL/EPSP/LOWER |
| Contact Force and Pressure | ✓ | ✓ | CONTF | /ANIM/VECT/CONT /ANIM/VECT/PCONT |
| Element Thinning and Thickness | ✓ | ✓ | THIN | /ANIM/ELEM/THIC /ANIM/SHELL/THIN |
| Element Energy | ✓ | ENERGY | /ANIM/ELEM/ENER /ANIM/ELEM/HOURG |
Optimization Results
References
