.secres file
The .secres file is an OptiStruct ASCII format results file.
File Creation
This file is created when SECTION Bulk Data Entry is present in the model and/or 1D or 3D pretension bolts are present in the model.
File Contents
File Format
| Type | Name | Content |
| NA | SECTION COORDINATE SYSTEMS | (XX,XY,XZ) (YX,YY,YZ) (ZX,ZY,ZZ) identify the axes of the coordinate system and (RX,RY,RZ) identifies the reference point |
| NA | Full Pretension Section Surface Name | Full name of the bolt pretension section used during the definition of the pretension bolt. |
| NA | SECTION RESULTANTS FOR SUBCASE # | Lists the resultant section forces and moments for each subcase #. |
