Sewing Tools
Connect two dissimilar 2D shell meshes using RBE3 connection.
If the nodes are really close to each other within a tolerance, they will snap without creating the RBE3 connection.
Create an assembly structure from a .csv file definition.
Create node-to-node CBUSH elements at the connector locations point/node or line.
Use the cfast converter tool to convert CFAST elements into CBAR/RBE3 (spiders). For thermoelastic analysis, the CFAST has no thermal expansion coefficient. CBAR is thermoelastic compatible.
Use the Stuck Node Creation tool to create (double) RBE3 connection to "stick" nodes on QUAD or TRIA elements to make the node displacements following the element ones.
Use the Linear Gap tool to create linear gap analysis cards for Nastran and OptiStruct.
In the steps below, you will create zero length elements and review.
