Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running
it through either component or element selection.
Define Nodal Equivalence
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running it through either component or element selection.
