Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes
are written in a certain displacement coordinate system.
Use the Dataname Viewer tool to display either scalar or new marker plots on elements/nodes associated to their data
names and attributes. For elements the link can be extended directly to the associated properties and materials.
Review Orientation Use the Orientation Review tool to display/review and modify frequently used coordinate systems used in CAE analysis.
Plot RBE/MPC
Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes are written in a certain displacement coordinate system.
Dataname Viewer
Use the Dataname Viewer tool to display either scalar or new marker plots on elements/nodes associated to their data names and attributes. For elements the link can be extended directly to the associated properties and materials.
Control IDs from Selection
Use the Control IDs from Selection tool to create a list of selected nodes/elements, review and control IDs.
