Ply Geometry Smoothing provides functionality to smooth finite element ply shapes, usually generated from concept
level composite freesize optimization, and to generate geometry from finite element ply shapes.
The Material Orientation tool provides several methods of assigning material x directions for shell and solid elements,
and additionally z directions for solid elements.
PCOMP From CSV
PCOMP from CSV generates HyperMesh composite properties from data defined in a .csv file.
Ply Geometry Smoothing provides functionality to smooth finite element ply shapes, usually generated from concept level composite freesize optimization, and to generate geometry from finite element ply shapes.
Ply Auto Rename
Ply Auto Rename changes ply names so that the assigned material, thickness and angle are appended.
FE Absorb Plies
FE Absorb Plies generates a ply-based model from zone-based properties.
The Material Orientation tool provides several methods of assigning material x directions for shell and solid elements, and additionally z directions for solid elements.
Shell To Solid Conversion
The Shell To Solid Conversion tool provides functionality to generate solid elements and material orientations from a ply based shell model.
