Create a quad dominant mapped mesh from orthogonal lines for global FE model creation. Bar/beam mesh will be created
around the edges. This is mainly used for the fuselage section.
Stiffened Panel Mesh
Create a quad dominant mapped mesh from orthogonal lines for global FE model creation. Bar/beam mesh will be created around the edges. This is mainly used for the fuselage section.
