Certification
To view the Certification ribbon, enable .
The Certification tools are used to asses methods on geometric regions (designpoints) representing a Structural Element. Methods are fed by attributes queried from FE model + FE results as well as external information not held by FE models.
- Create some Designpointsets
- Create and organize Designpoints in Designpoinsets
- Assign Structuralproperties to Designpoints
- Add Methods to evaluate (from registered methods)
- Select loadcases to loop through
- Run
- Contour or export Table to report
Designpointsets, Designpoints, Structuralproperties and (Designpoint) Methods are HyperMesh entities persistent in binary file.
- Beam
- Panel_composite
- Panel_metallic
- Rivet
- Spring
- Generic
General Concepts
The aim of the Certification tools is to instrument a “region” of an FE-model and evaluate an external math function to assess margin of safety while considering “true” geometry and properties of that region.
In this matter, the so-called region is assigned a “virtual property”, which is a placeholder to provide all required details to better represents physics and geometry.
Such regions are grouped together in sets where functions are assessed under multiple load cases.
Critical margins of safety can then be found to down select critical load cases.
When such an evaluation is done, the aim is to be able to update virtual properties of failed areas to re-assess certification methods.
- Designpointset
- Designpoint
- Structuralproperty
- Designpointmethod
- Beam
- Rivet
- Spring
- Panel Metallic
- Panel Composite
- Generic
Designpoint is the “region” which is instrumented; designpoint is the FE description of engineering concept denoted as “Structural Element”, that is the geometric zone of interest with details not modeled in FE world. To fill such gap, we introduce another entity called “Structural property”. Depending on the designpoint config, Structural property will have different set of datanames that you can fill. Each designpoint can have its own structural property.
In this documentation, we can either refer to Structural Element or designpoint when it come to the HyperMesh entity designpoint.
Each designpointset config, except Generic, comes with an algorithm which will absorb Structural Elements from your selection and various options. You will then populate and organize designpointsets with several designpoints to assess methods.
Each designpoint is a collection of several elements which materialize a geometric region on the FE model.
Technically, designpoint is not limited to elements; it could point to any HyperMesh entity. However, the current released configs are either made of elements which form a pattern or freebody sections.
- Python functions
- Compose (OML) functions
- C++ dynamic libraries (DLL)
- Tcl procedures
The framework embeds Python/Tcl/Compose interpreters to evaluate such functions. When assigned to a designpointset, registered function becomes a designpointmethod entity. The framework will query all needed result and model info and pass them to methods for evaluation.
