Create Spring Structural Elements
The Spring tool recognizes CBUSH connections and absorbs them as springs.
From the Certification ribbon, click the Spring
tool.
Figure 1. -
When Structural elements are created, a structural property can be selected.
Click
to define how properties are assigned.
Each structural element must have a structural property assigned to it in order to run method.- Single property
- Assigns the same structuralproperty entity to all designpoints.
- Duplicate and assign property to all
- Creates a new instance of selected structuralproperty and assign the copy to all designpoints.
- Duplicate and assign property per designpoint
- Creates a new instance of selected structuralproperty per designpoint entity.
- This option performs a deep copy, meaning the structural property's references, such as materiel/property, are also copied. Each structural property generated is fully independent.
- This is useful for design exploration where you will update structural properties separately.
- Select CBUSH elements to absorb as springs.
- Optional:
Select a destination DesignPointSet to hold newly created designpoints.
If no set is selected, a new one will be created with config Spring.
If you enter this menu from the Certification Browser context menu using Auto DDP, then the selector will be pre-populated with the selected designpointset.
- Specify a structuralproperty entity to assign.
On the guide bar, click one of the following:
- Save changes and stay in the tool
- Save changes and close the tool
